ID help
ID help
So, I already know my car is a mash-up of crap. That's why I don't mind tearing it apart and building what I want. (LS/T56, rack and pinion, VBP suspension).
VIN shows it's a 68. Titled as a 68. Most of the parts on it are not 68. No worries. However when I started poking around I noticed this Tag under the hood above the steering column. It has the same serial numbers as my VIN, but claims year '77. Anyone have any ideas on this??
It's a chrome bumper car, so all of the parts on it are 68-72ish.
As far as I know.
Under hood ID tag
VIN plate
My original (ancient) thread with most of the info I know about the car, which I'll hopefully be updating today with some recent work done to it, if interested.
https://www.corvetteforum.com/forums...n-s-vette.html
As far as I know.
Under hood ID tag
VIN plate
If you check out my build post I have most of the info there I think.
None of the engine/trans is original to the car.
I looked up the castings a long time ago, and the block is a 71 passenger 454 block.
Heads are truck peanut port with matching intake manifold.
Trans is a Muncie. Late 60's/Early 70's by the numbers I can see from underneath.
Will find more details on it once I have the engine/trans out of the car.
I'm mostly just curious why the VIN and that plate match, but the years are so far off.
Your under hood tag is not original to any Corvette. It's from the Bureau of Automotive Repair, whom ever that is?
Your car would have had an engine/emission sticker that looked like this, but specific to your cars original engine.
https://www.corvetteforum.com/forums...n-sticker.html
It was located on the flat spot behind the power brake booster/master cylinder.
The flat area behind the MC is where this sticker is.
I'm really not concerned with originality, just wanted some feedback on what that sticker might be.
Everyone's insight has been great. Thanks for all the input.
Yeah, thats a sticker used by the BAR for engine swaps. Tells the smog check technician what the engine is and what emissions equipment are needed on it. Not sure what state its from but if it a California one its pretty old. I once put a Oldsmobile BB in a 67 Chevy pickup and had to take it to a referee to have it certified, put a similar sticker on the door jamb for future smog checks.
I'm sure it has a long rough history. I don't have any records or anything. All I know is the guy I bought it from had it stashed in the corner of his massive garage, full of corvettes and thunderbirds, for quite a few years.
