Motor Mount Bolt missing - '72 sbc 350
I was checking my starter today and noticed the center bolt that goes into the block on my RH motor mount is missing?!? I've got a 72 base engine 350 4speed.
So I looked at the drivers side and it seems the center bolt is there, but it's coming out. i.e., it's not tightened down.
Does anyone know the size of this missing bolt? also what this bolt should be torqued down too?
I plan on replacing it asap, and tightening down the one of the drivers side too. I checked the other bolts on the mounts and they seem fine, but the ones in the center have issues.
thanks! JH
thanks! JH
Received 2,878 Likes
Hi jh,
I believe the engine mount to engine block bolts are 3/8"x16x7/8".
Torque 22-30 lbs.ft. according to the AIM.
Regards,
Alan
Regards,
Alan
I have a similar issue where the passenger side motor mount center bolt fell out and the the other two were loosing up. Mine is a 1974 and the AIM for my year states it a #331246 bolt, 3/8" -- 16 thread and a length of 15/16". The torque is 30 to 40 foot-pounds. You may check your 1972 AIM (or get one if you don't) since there seems a different values from 1971 to 1974, where 1972 may fall in with 1971 or 1974.
Hi,
I don't know why the difference in the AIMs. Bolt part # changed.
CJC, what's the motor mount part # in your 74 AIM.
In 71 it's 3980701. Did it change?
Regards,
Alan
Regards,
Alan
my 72 AIM
My 72 AIM shows on UPC 6 Sheet B3
screw 3748038, 22 to 30 ft lbs.
motor mount 3980701 and I do not see any rolling changes for the motor mount either.
How do you guys know the bolt size from the AIM? I suppose if I had a part number list that has it?
I usually put permatex B on bolts like these that see vibration.
Hope this helps. BTW, getting a torque wrench on these was a trick but enough different wobble extensions will get it done, LOL's!
Hi 20,
I use a couple of old GM parts books.
There are 'some' exploded drawings that show many of the fastener sizes, but not the hardness spec.
Also, 'some' of the fasteners are shown by part number in the parts books.
I also use J Tripoli's Chassis Book which lists a lot of fastener sizes.
As a last ditch method I take the bolt out and size it.
Regards,
Alan
Regards,
Alan
Thanks everyone for your help!
I suppose the easiest way to get the bolt size might be for me to remove the drivers side bolt, which is loose anyways, match it up, and then screw it back in? Do you think that's an ok way to go, or will I have problems lining up the LH bolt again if I remove it?
Much Thanks!
Hi 20,
Regards,
Alan
Regards,
Alan
Probably the last method for me, most of the time, might be the quickest, ha!
Hi jh,
I think you're safe going out and buying a 3/8"x16x7/8" bolt as was suggested.
Just be careful that you get it started straight and don't force it.
Since it's a blind hole I'd take a moment to clean it out a little first.
Regards,
Alan
Regards,
Alan
Received 1,470 Likes
Cruise-In II Veteran
Hi 20,
There's also earlier catalogues called Corvette Chassis and Body Parts Catalogues.
I bought a used one in nice condition dated 1977 at Carlisle last summer for $10. (The cover says 53-77)
It's been marked up a little in a way that makes me think it spent at least part of it's life at a dealership.
It has the specs for many fasteners so is certainly worth the $.
Good Luck!
Regards,
Alan
Good Luck!
Regards,
Alan
Received 1,253 Likes
Jhiltonn I'm glad you posted about that bolt. It was a nice warm (60*) day so I decided to change the oil and filter and your post made me look at that bolt and my drivers side was loose.
Thanks again for posting or I would have lost that same bolt.
Regards,PG.
Regards,PG.
I would go a minimum of 30ft/lbs on that bolt maybe even more.....22ft/lbs is too low for a 3/8ths fastener to properly stretch it. 22ft/lbs.....no wonder they are falling out!
Thanks again everyone for all the great help!!
I wasn't able to find a 7/8" long bolt, which seems a little short to me(but what do I know?!?!), so I chose a 1" long, 3/8" 16, grade 8 bolt, instead of a 3/4" length version. Hopefully the 7/8" vs. 1" won't be a problem. I'll try the permatex B on the threads too!
BTW: Where would I find an original bolt if I wanted to go that route?
Lastly, I found a copy of the Chevy Corvette Parts & Illustration guide catalog for $25 on eBay... Sounds like a great must have book, especially if it lists all the fastener , screw and bolt sizes! Thanks for that tip too!
Joe
Joe
Joe
Joe
Suggestion.
You can order these bolts from the Corvette Vendors for not too much. Or you can do my bubba fix, hacksaw an 1/8" off the grade 8, LOL's! an eight inch of flat washers is likely a better choice though
Wow, I found and bought a copy of this book on ebay too just now, and you got a better deal than I did though, ha!
Joe
Joe
