Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 08-06-2002, 06:48 PM   #1
Stewart's74
CF Senior Member
Stewart's74's Avatar
Location: New Jersey Grand Poobah of the "Hobbiest Nation"
Send a message via AIM to Stewart's74
Default Is it ok to use teflon tape on Fuel line?
I've got a freekin leak on my steel fuel line threads that go from the pump to the carb. Can I use Teflon tape? :confused:
Stewart's74 is offline   Reply With Quote
Old 08-06-2002, 06:50 PM   #2
Markm10431
CF Senior Member
St. Jude Donor '08-'09,'13, '14
Markm10431's Avatar
Default Re: Is it ok to use teflon tape on Fuel line? (Stewart's74)
noooooooooo :nono:
Markm10431 is offline   Reply With Quote
Old 08-06-2002, 06:51 PM   #3
Stingy74
CF Senior Member
Stingy74's Avatar
Send a message via MSN to Stingy74
Default Re: Is it ok to use teflon tape on Fuel line? (Markm10431)
I'd use the pipe dope stuff. It's got teflon in it and looks like toothpaste.
Stingy74 is offline   Reply With Quote
Old 08-06-2002, 06:52 PM   #4
LAvetteman
CF Senior Member
St. Jude Contributor
Nope, teflon wont hold up to gasoline. If it is a flare connection the flare has to seal the deal.
LAvetteman is offline   Reply With Quote
Old 08-06-2002, 06:53 PM   #5
GrandSportC3
CF Senior Member
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03 & '06
GrandSportC3's Avatar
Send a message via AIM to GrandSportC3 Send a message via Yahoo to GrandSportC3 Send a message via Skype™ to GrandSportC3
I use a thread sealer that contains teflon...
:cheers:
Olivier
GrandSportC3 is offline   Reply With Quote
Old 08-06-2002, 06:55 PM   #6
LT1driver
CF Senior Member
LT1driver's Avatar
Default Re: Is it ok to use teflon tape on Fuel line? (GrandSportC3)
sorry to disagree, i rountinely use it on my carbs about 1/4 was up threads away from end to keep from getting it in fuel line, works for me for over 35 years :cheers:
LT1driver is offline   Reply With Quote
Old 08-06-2002, 06:55 PM   #7
Scott78
CF Senior Member
Scott78's Avatar
Send a message via ICQ to Scott78
Default Re: Is it ok to use teflon tape on Fuel line? (71,454,4spd)
Just as quoted above, flare fittings shouldn't need a sealer. If they leak you need to repair/replace the offending parts. After numerous times of being removed and retightened you can get grooves in the flare that will not seal. My thoughts about gasoline is that it's to volatile to take chances with.
Scott
[Modified by Scott78, 4:59 PM 8/6/2002]
Scott78 is offline   Reply With Quote
Old 08-06-2002, 07:02 PM   #8
Fevre
CF Senior Member
Fevre's Avatar
Default Re: Is it ok to use teflon tape on Fuel line? (Scott78)
Just as quoted above, flare fittings shoudn't need a sealer. If they leak you need to repair/replace the offending parts.
Scott
On flare fittings even if you use the correct tape, comes in a yellow cont and is yellow, if can leak between the flare fitting and the nut seeping out of the nut/pipe area. You can use the tape on say a barbed non flared fitting going into a pressure regulator or filter. Read the side of the tape cont and it will state what it can be used for. I got my yellow tape at Lowes or Home Depot.
[Modified by Fevre, 5:03 PM 8/6/2002]
Fevre is offline   Reply With Quote
Old 08-06-2002, 07:58 PM   #9
MotorHead
CF Senior Member
MotorHead's Avatar
Location: Never argue with Morons. If you do, you'll lower yourself to their standards, and they'll win, based on experience !!!
Default Re: Is it ok to use teflon tape on Fuel line? (Fevre)
I've got some of the yellow gas teflon tape in my fuel line too, works fine :D
MotorHead is offline   Reply With Quote
Old 08-06-2002, 08:03 PM   #10
tboltkc
CF Member
Send a message via AIM to tboltkc
Default Re: Is it ok to use teflon tape on Fuel line? (MotorHead)
I've heard of people using fishing line or some such thing in the fuel connections. What's that about and does that work?
tboltkc is offline   Reply With Quote
Old 08-06-2002, 08:46 PM   #11
Rockn-Roll
CF Senior Member
Rockn-Roll's Avatar
Default Re: Is it ok to use teflon tape on Fuel line? (tboltkc)
Fishing line is made of teflon...gas will eat it up. If you aren't sure if it's safe, then take two small pieces of the material and set one of them on your work bench and the other one in an open container (like a glass jar) of gas...perhaps a pint jar about 1/2 full and set it next to the other one on the work bench. Let it soak in the gas for a day or two then take the material out and let it dry. If it's in the same condition as the original piece then it's safe. Come back here and let us know what you find.
Rockn-Roll is offline   Reply With Quote
Old 08-06-2002, 09:09 PM   #12
Jack Bauer
CF Senior Member
Jack Bauer's Avatar
sure you can.... but it won't do you any good. the steel lines seal by a compression of a flair on the end that is swedged between the fitting and the body of the fuel pump or carburator, whichever end is leaking. the threads don't have anything to do with sealing the fluid other than tightening that compression. check to see if either the flair on the tube is damaged or the seat in the body. if neither of them are damaged, then inspect the line for a crack which will most likely show up in the tube seam.
wow! holy delayed reactions, batman! there was only one response when i replied to this. how does that work???
[Modified by clutchdust, 5:13 PM 8/6/2002]
Jack Bauer is offline   Reply With Quote
Old 08-07-2002, 11:50 AM   #13
Schwee
CF Senior Member
Remember this forever and it will answer a lot of questions:
Teflon tape is a thread lubricant, not a sealant.
Schwee is offline   Reply With Quote
Old 08-07-2002, 01:16 PM   #14
The Dude
CF Senior Member
The Dude's Avatar
Default Re: Is it ok to use teflon tape on Fuel line? (Schwee)
Click the image to open in full size.
That having been said, I do use teflon tape on the fuel line to fuel bowl fittings on my Holley. Why? Because those lines are on and off so often that I want to do whatever I can to prevent galling and/or cross-threading in the heat of the moment.
The Dude is offline   Reply With Quote
Old 08-07-2002, 01:21 PM   #15
Fevre
CF Senior Member
Fevre's Avatar
Default Re: Is it ok to use teflon tape on Fuel line? (The Dude)
Why then is there different types, ie white for water lines and yellow for gas lines if all it does it lubricate? I think it also seals or there would be no reason for the heavier duty yellow type. JMHO
Old 08-07-2002, 01:56 PM   #16
slim
CF Member
I've seen white teflon tape on the threads of the hose going into the handle at gas pumps.
slim is offline   Reply With Quote
Old 08-07-2002, 03:42 PM   #17
BB wowbagger
CF Senior Member
BB wowbagger's Avatar
Send a message via MSN to BB wowbagger
Default Re: Is it ok to use teflon tape on Fuel line? (slim)
I run Steelbraide teflon hoses to my carb,and the guy at the speedshop told me that TEFLON can be used to allmost all fluids.Breakfluid,coolant,Gasoline,Diese l...Teflon hoses rules. :cheers:
The problem with teflon tape is that small pieces can loosen from it, and clog up the carb,otherwise i see no problem
[Modified by BB wowbagger, 8:44 PM 8/7/2002]
BB wowbagger is offline   Reply With Quote
Old 08-07-2002, 07:29 PM   #18
Matt Gruber
CF Senior Member
i've never used anything on a flare fitting.
But if one was buggered up real bad, i guess some JB Weld would be a temporary fix. i don't see how you could apply tape to the flare without risking a piece of it getting into the carb and plugging it up, or blocking the fuel flow.
once in a while i replace the line with brake line; it has a nice perfect flare; bend to fit; never leaks
Matt Gruber is offline   Reply With Quote
Old 08-07-2002, 10:31 PM   #19
SLICKMAN
CF Senior Member
SLICKMAN's Avatar
Default Re: Is it ok to use teflon tape on Fuel line? (Matt Gruber)
I have used teflon tape for years on fuel lines and never had any problems. Its the best you can use...... See below; You can view this here http://www.resitape.com/en/overview_mgst.html
PTFE has been used as a seal in critical operations for close on 50 years. It is undoubtedly the material of choice for applications that require totally reliable sealing in any environment, from household water systems to the most aggressive and hazardous chemicals. The properties that make PTFE ideally suited for all sealing applications include:
Its non-wetting non-stick surface is resistant to enzymatic and microbiological attack and does not enable fungal or bacterial growth;
Its chemically pure and inert state gives unmatched resistance to water, gases, solvents, acids, alkalis and other reactive media;
Its lack of leach-able additives ensures no effect whatsoever on process fluids;
Its resistance to cracking and embrittlement even after long-term use;
Its lubricity prevents the binding and sticking of pipes.
Its retention of these properties over a very wide temperature range, from about -240C to + 260C
PTFE tapes can be used with all types of pipe, including iron, steel, copper, brass, alloys, plastics and even rubber. The tape is highly pliable so that it embeds in the threads, and remains compliant at high and low temperatures even at high pressure.
A Quality Product
The standard density of unsintered PTFE is 1.5 g/cm3 and this is reduced during the manufacturing process, often as low as 0.3 g/cm3.
By stretching the tape from its original density, improved drape and elasticity is added, thus improving its sealing properties. It must be noted however that PTFE tape is also a permeable fibrous product and that during the stretching process the pores between the fibers are being enlarged. It should be noted that tape performance is determined primarily by the level and balance of tensile strength and elongation between the longitudinal and transverse directions. These factors, along with the combination of thickness and density are crucial to the effectiveness of the tape as a sealant.
Unfortunately, in an effort to reduce costs to satisfy pressures in the distribution chain, much of the tape offered for sale today is stretched excessively and in an unbalanced ratio thus making the product almost unsuitable for the purpose for which it was manufactured. We kindly suggest that all users specify their desire for tapes from quality producers that meet acknowledged international performance standards
[Modified by SLICKMAN, 9:33 PM 8/7/2002]
SLICKMAN is offline   Reply With Quote
Old 08-08-2002, 10:08 AM   #20
Matt Gruber
CF Senior Member
Default Re: Is it ok to use teflon tape on Fuel line? (SLICKMAN)
slickman(and anyone using tape on flare fittings)
QUESTION
do you put it on:
1. the flare that makes the seal?
2. the nut that tightens the flare?
3. both
4. none
i am curious as to exactly what you are doing
[Modified by Matt Gruber, 9:57 AM 8/8/2002]
Reload this Page Is it ok to use teflon tape on Fuel line?
Tags
brake, corvette, fitting, flare, fluid, fuel, gasoline, leaking, line, lines, ptfe, resistance, resitant, tape, teflon
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Fuel Line Inlet AGVI C3 Tech/Performance 30 11-18-2004 12:59 PM
Fuel Pump 101 zymurgist C3 Tech/Performance 13 07-09-2003 11:10 AM
Fuel Line Leak At Carb John's Shark C3 Tech/Performance 22 03-21-2002 08:50 AM
Would you use teflon for sealing up fuel lines? MARKUS_P C3 Tech/Performance 10 12-28-2001 06:20 PM
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
