POR-15 quantity for frame
Hey guys, especially the ones that did a frame of resto. How much por-15 should I buy to paint the whole frame? Is 1 quart enough or should I go with a gallon?
Re: POR-15 quantity for frame (Lohkay)
2 quarts should be enough but if you don't use it all at once it'll get hard very fast in the can. If you get more, get more cans not 1 big one.
Marck
Marck
One quart can did two coats on my frame. I bought two and am using the second can on parts like bumper brackets, steel wheels, scattershield, etc.
Hint: When closing a part can, place plastic warp losely over the mouth of the can before tapping the lid on. This saved 3/4 of a can from hardening on me. How? The fumes inside expanded and "popped" the lid off, but the plastic held by bubbling up without breaking.
Hint 2: Have "lots" of air circulation if brushing this stuff on. If spraying, follow the manufacturers cautions completely. Get proper equipment so as NOT to breathe those fumes while spraying!
Amazing stuff.......dries VERY hard and leaves no brush marks.
[Modified by 67HEAVEN, 7:14 AM 8/5/2002]
Re: POR-15 quantity for frame (67HEAVEN)
When you did your frame did you coat the entire frame at the same time or in sections? Working on stripping & preping mine now, it would be easier to do in sections & finish one side then flip it over. Also how long can you wait between coats? Can I paint the second coat a few days later? Work schedule & the honey do's are getting in the way :lol:
Re: POR-15 quantity for frame (70BBvert)
Then, I painted (brush) the underside first (frame was upside down). I let it dry overnight....applied second coat.
After another overnight drying, I flipped the frame over and did the same thing to the topside - two coats.
If you need to wait longer between coats, be sure to vacuum/rub down the surface again as dust build up is fast.
My final step was to spray a coat of Tremclad Gloss Black to prevent UV fading of the POR-15 (as they warn about on their label).
Last time I used the stuff, I poured the leftover into a 1 quart canning jar
and used the canning lids. Stuff lasted a long time, didn't dry up in storage.
Buying a gallon might be tempting for the price but the quanity is to much! I think one quart would do it but get get two quarts just in case. I bought the six pack of 1/2 pint cans (3 gloss, 3 flat) to keep on hand in my garage. They are easier to work with and you don't waste as much!
Two quarts is about right, and I did mine in sections. Here's a tip on how to keep it from hardening, this for the black. Drill a couple small holes in the lid and use screws to plug them up after you are done. This way you never have to take the lid off. Saved me a quart. You can't do that with the silver as it needs to be stirred but the black is Ok.
Have fun!
Have fun!
