Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 08-02-2002, 05:29 PM   #1
SLO RDE
CF Senior Member
SLO RDE's Avatar
Default Edelbrock fuel pump install on a 76?
whats up I just got some parts in the mail and Iam looking at this edelbrock fuel pump(1721)I got.It only has a 3/8 inlet for a line coming in and a line going to my carb My stock fuel pump has two rubber hoses going in and a fuel line going to my carb? I'am sure I'am not the only one to install this fuel pump to a 76, 350ci so does anybody know the way to change this over?What size fuel lines or fittings or anything else will I have to buy?I hate making 30 trips to the parts store and trying to guess what sizes and just what I really need.(everybody knows your on your own when you go to the stores)Any help with this would be awesome Thanks.Carver SLO RDE (76 L-48 vette)
SLO RDE is offline   Reply With Quote
Old 08-02-2002, 11:42 PM   #2
Tominator
CF Senior Member
Tominator's Avatar
Default Re: Edelbrock fuel pump install on a 76? (SLO RDE)
As a fellow 76 L48 owner I wish I could help but I can't so heres a TTT for you. :yesnod:
Tominator is offline   Reply With Quote
Old 08-02-2002, 11:50 PM   #3
glen242
CF Senior Member
One line is a fuel return line. I believe you can just plug it, if you want to.
I just replaced my pump with a stock unit. Why did you go with the Edelbrock?
[Modified by glen242, 11:00 PM 8/2/2002]
glen242 is offline   Reply With Quote
Old 08-03-2002, 01:03 AM   #4
73 LS-4
CF Senior Member
73 LS-4's Avatar
The vapor return line can be plugged, but it's possible to have vapor lock problems with this setup. I have the same pump except for a BB and haven't had any problems as of yet. Are you still using the quadrajet? If so i was able to run braided line with it and the proper AN fittings to give it a profesional look but it did take a few trips to the speed shop. If you have any specific questions let me know.
:cheers:
Pat Kunz
73 LS-4 is offline   Reply With Quote
Old 08-03-2002, 06:35 AM   #5
AlwaysWave
CF Senior Member
Cruise-In III Veteran
AlwaysWave's Avatar
I have a 72. I don't recall the part # of my Edelbrock pump, but it's the "street" pump. To fit the fuel lines I had to use the underside adaptor which costs extra. Both fittings are 3/8 90 degree. The line to the carb is routed to a Holley fuel pressure regulator. One outlet of the regulator is plumbed to the fuel return to tank line.
AlwaysWave is offline   Reply With Quote
Old 08-03-2002, 08:28 AM   #6
Eddie 70
CF Senior Member
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Support Corvetteforum!
Eddie 70's Avatar
Default Re: Edelbrock fuel pump install on a 76? (AlwaysWave)
Where did you find the fuel pressure regulator? I may wind up having to get one. I ordered one fuel pump and got a slightly different one that may have too much pressure, 7 psi, I think.
Eddie 70 is offline   Reply With Quote
Old 08-03-2002, 01:26 PM   #7
AlwaysWave
CF Senior Member
AlwaysWave's Avatar
Default Re: Edelbrock fuel pump install on a 76? (Eddie 96)
Summit catalog. A Holley #803 or 804. It's the 4 1/2 to 9 lb regulator. Sells for around $20. I have it set for 5 1/2 lbs which is about the max an Edelbrock carb likes.
Reload this Page Edelbrock fuel pump install on a 76?
Tags
76, c3, change, corvette, diagram, edelbrock, fuel, gas, howto, install, location, pump, replacement, return, stingray
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
