Edelbrock Performer RPM Intake Manifold install/adjustments
Finishing up my Edelbrock Performer RPM Intake Manifold install and wanted to know if there were any adjustments that needed to be made with carb when tuning and re-timing. Like, secondary springs or fuel idle mixture screws. I have a Holly 0-9895. Using AFR 180cc heads, 1.6 roller rockers, headers, dual exhaust, etc. Complete top-end rebuild. Curious what may need to be addressed with this upgrade. Thanks....
Holley describes that carburetor as an emissions control compliant carb, strange choice for a highly modified engine? Mixture screws will have to be adjusted but beyond that unless you run a dyno mixture test will have to guess based on performance and plug coloring.
https://www.holley.com/products/fuel...t/parts/0-9895
I would be more concerned with a spreadbore carb being mounted on a square bore intake unless you have an adapter which would defeat the purpose to start with and also create hood clearance problems unless a high rise hood is installed. When you can replace the carb I can vouch for the Holley Street avenger series. I run a 770 cfm with great success.
with the R.P.M Air gap your more than likely going to in crease the size of your squirter(s) and you probably need to up your jet sizes. i have an quick fuel H.P 750 and it is a beautiful thing. could not recommend anything more highly.
I am using a Holley 4175 650 spread bore vacuum secondary emission carb on my just rebuilt 355 AFR aluminum head, roller cam, 10.2:1 engine and the only change I made to the carb is upping the size of the primary jets from 59-2 to 63's-carb runs great and pulls hard…probably needs a bigger jet and i am planning to add an adjustable secondary metering block but the 4175 runs surprisingly well. The 4175 "emissions" designation is really just the primary 59-2 emissions jet. Other than that it is a 650 CFM Q jet replacement carb…it was designed originally to be an emissions carb replacement for the 78 L-82 Qjet
the part number is 122-63
Thank you. In the details it says nothing about fitting a 4175 but it's all I see for a 63 size. I'm guessing they are easy to replace?
https://www.holley.com/products/fuel...s/parts/122-63
Actually, this is now my only real question:
I have the Edelbrock Performer RPM 7104 Intake Manifold, the Holley 108-118 base gasket, and the Holley 0-9895 carburetor. Am I using an incorrect configuration for spreadbore?
http://www.edelbrock.com/automotive/...r-rpm-sb.shtml
https://www.holley.com/products/Fuel.../parts/108-118
My emissions compliant carburetor pulled 451 hp / 485 lb-ft torque on the engine dyno... I'm sure if I switched to a Holley double pumper the numbers would easily double, but I'm happy for now.
No, you are okay. I hadn't seen that they offer a spreadbore version of the performer rpm. Used to only be the 7101 but you have a spreadbore so shouldn't be any problem other than dialing in the tune once you get it running and read the plugs.
Good Luck,
Eric
Good Luck,
Eric
I thought so, thanks. Some of these responses have me wondering about jet size but it was running great on the Performer Intake. As mentioned previously, I'm thinking all I have to do is adjust the fuel idle mixture screws to dial it in.
