Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 08-01-2002, 04:36 PM   #1
gerry72
CF Senior Member
Default Re: What does this mean......10/10 crank (Rick Church)
Ground .010" on the main journals and .010" on the rod journals.
gerry72 is offline   Reply With Quote
Old 08-01-2002, 04:47 PM   #2
burners
CF Senior Member
Cruise-In IV Veteran
Cruise-In V Veteran
burners's Avatar
What Gerry said, ground 10 thousandths under standard. Or it could mean a perfect 10 out of 10 crank, all the right curves, looks good in a bikini and all that.
burners is offline   Reply With Quote
Old 08-01-2002, 05:20 PM   #3
burners
CF Senior Member
Cruise-In V Veteran
burners's Avatar
No performance effect. It just means that the crank was worn enough that it required machining to smooth and true the journals. When you rebuild an engine it is usually done. Future rebuilds may require it as well. You can turn a crank as much as 30 thou. Bearings have to match it as well and are sold in standard sizes of 10, 20 and 30 under.
Old 08-01-2002, 05:36 PM   #4
The Dude
CF Senior Member
The Dude's Avatar
Default Re: What does this mean......10/10 crank (burners)
That's one of those backasswards things that always threw me. It took me the longest time to grasp that, if a crank was turned .010" undersized, for example, that you order .010" under bearings even though they're thicker than standard to make up the difference. But, hey, I graduated from a Cal State school so allowances must be made. :lol:
[Modified by The Dude, 1:37 PM 8/1/2002]
The Dude is offline   Reply With Quote
Reload this Page What does this mean......10/10 crank
Tags
010, 10, 1010, 25, crank, crankshaft, cutting, degrees, mean, motor, turned
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
