Need help identifying wires on my 1973 Vette. Video inside to help
TheCorvetteBen
Please watch the video and tell me what these go to. i dont seem to have these wires listed on my wiring diagram...
Thanks!
Thanks!
Received 3,139 Likes
I can't speak for certain on the 73 but I believe most of what your looking at is the remaining bits to the TCS wiring and the idle stop solenoid wire.
On the plug for the solenoid, there should be two wires, one goes over to the temp sensor in the passenger head (green I think) and the tan wire going into the firewall to the switch on the gas pedal.
Have a look at this thread and see if it helps, keeping in mind it's talking about a 72 and then there's some info on the differences between SB and BB and standard vs auto
http://forums.corvetteforum.com/c3-g...ommet-tcs.html
HIH
M
HIH
M
Transmission Controlled Spark. It prevented vacuum advance until top gear and fully warmed up.
TheCorvetteBen
71 had a slightly different set up CEC I think they called it, included the idle stop solenoid.
I thought they used the system right up into 77 in one form or another but I could be wrong, 72 and 73 I'm fairly sure about
Check here for detailed 73 TCS info if you wish
http://www.73spot.com/index_stats_fi...ission/tcs.htm
As for the wiring diagrams, I've got several, some show it, most don't or it's on a separate page
HIH
M
