Sachs Clutch?
While not a BB, I've had a Sachs clutch in mine for about a year and a half. It's been to the dragstrip, has done a lot of burnouts and hard launches and it's now on the workbench, because the engine got pulled and it's still got some life left to it.
I was happy with how it worked and with a stock engine, I think that it will do fine, good pedal feel, good grab, but if you are running or planning to run a modified engine or really flog your C3 hard, then I'd recommend going with a street/strip or race clutch from McLeod or Centerforce (for $348, I'm going with the Centerforce II for my '74).
Received 3,043 Likes
St. Jude Donor '05
Nothing wrong with Sachs they have been around forever
It was short lived Throwout Bearing started making noise out it came. I ordered a Hays just the way it was riveted looked like crap. I read a article on Spec brand and it got me second guessing my choice. Do your own research there are plenty out there.
The Hayes set-up I had before it threw of a couple of heavy washers off the pressure plate. The second one went half way through the bell housing. So, no more Hayes and a Lakewood now.
by chance...if I am looking to move from a 10.4 to 11" disc...do I need to change anythign with the bellhousing or inspection plates?
Thanks,
R
Thanks,
R
I have the sachs 11 inch. You have to have the 11 inch 168 tooth flywheel and matching starter motor.
As to a bell housing. I don't have a clue on stock stuff because I use blow proof bell housings
gkull....yes...have the 168 and matching starter...i think the bellhousings are the same...but maybe the inspection plate is different....
anyone know about the inspection plate (engine side of bellhousing)?
R
R
Sachs are more than up to the task.
As for factory type bells, the xxx403 (anybody need one?) fits with the 10.4"/153 tooth, while the xxx621 fits with the 11"/168 tooth setup. That said, if you're application includes high-perf/HD abuse, get a genuine SFI certified clutch setup and scattershield w/engine plate, and pick somewhere else to save a few bucks. Seriously.
And, FWIW, if your personal driving preferences happen to put you nearer to the AX/RR corner of the performance envelope, I highly suggest no more than a 15-20# flywheel. IMHO the reward for learning how to drive more proficiently with a lighter flywheel is well worth the extra effort. My $.02
