Build thread: LSx 6.0 swapped c3
#41
Regarding fuel system, no need for return. They're not used on any more GM setups. Get the F body intank from vetteworks. Save yourself time and money and go with OEM plastic lines and fittings.
On the harness:
Your motor is a 24x reluctor. That means you'll need an ecu and harness made for it. The 411 ecu is very common and will support cable or DBW.
If you don't already have a DBW pedal ($100), TAC ($250), TAC harness ($50), TB ($150), save the money and just pick up a cable TB. You'll need a 3 bolt TB from either an f body or truck.
Get your harness and tune set up for cable (IAC driver).
Honestly, building a motor and sourcing parts the way you are is the most expensive way. I would suggest hitting a junkyard and stripping all the parts, sensors, etc you'll need.
On the harness:
#42
It looks like it to Me that Your mechanical knowlege is a bit limited on gen 3 motors, not trying to put You down or nothin but they can be a little complicated to the novice.
Garys68 and 74modified got some good advice here. With the route You're going buying everything new, have You thought about using the MSD unit to run the coils and using a Carburator ? This could save You lots of time and money. Expecially on computer reflash and tuning.
One more thing before starting a new gen3 and up Engine You must prime the Oil pump , it will not pick up oil from the pan if it is dry. Kent Moore makes a special tool to do this . This is IMPORTANT so don't skip this.
#43
I am with Gary. You could get 4.8 or 5.3 valve covers, sensors ect. from the salvage yard. I am running a Gen III with cable throttle and a 411 ECM. I have an in-tank pump and nylon fuel lines and find that setup perfect for what I need.
Depending on your budget and desired results, bigger is not always better. Fuel cells, superchargers, 1000 gal/hr fuel pumps, ported throttle bodies, radical cams, and other ideas may not be the best for your particular build.
Instead of all of that stuff, I would look at an overdrive transmission instead of the TH350. Again - depending on how you want to use the car - Being able to enjoy the benefits of the modern engine and controls to run OD is one of the main reasons I decided to swap in an LS.
#44
Gen 3 ecu 411
5.3 valve covers and all sensors
Db cable throttle body
Im not buying a wiring harness and sending it off. Psi will build me one.
Also i found a camaro ls1 part out. Ill go pick up his
Oil pan
All accessories and brackets
#45
#46
The transmission goes off to get built to handle 600whp. The lq9 heads, aluminum roller rockers, hardened push rods, zo6 cam, f body oil pan, and all gaskets and hardware come in Friday.
#48
Its coming along amazing. I pulled the interor and wires. The gauges will be dummy. Were using a racepack, 5.3 headers vbanded, and a 76mm precision. The lq9 is almost fully built. Were using a custom a2w tank in a custom fuel cell. With the holley mid ram intake and a custom a2w intercooler built into the intake. The a2w intercooler is one bad mother ****er. Look up "crusty nova 417 motorsports" and check it out. Were using holley efi tuning. It will take time. The projected power to start is 625whp then by the end of next year at 850rwhp.
My headers are getting refreshed and i got a 350turbo shell to mount the lq9 and start tacking up the piping for the 76mm.
#49
#50
I did the LQ9 swap last year and love it. Bored .030 over with cam. I used the Holley Avenger EMS for my build. I would recommend going with the Holley dominator for your build. More I/O. Can get the harness for LS so you don't have to make a harness and you can tune a number of different areas. Check it out.https://www.holley.com/products/ls_p.../parts/554-114 I also used the Holley Accessories brackets but with a turbo you may need custom brackets. You should go to the LS forum and look at all the conversions. That's where I posted my build.
#51
I wont be using dominator. Just basic holley efi. Also ill be making a custom aluminum dash to mount the holley dash.
#53
I agree, but i got them free
I finished pulling all the wiring. All that is left is the wires for the windows, ignition wiring coming out of the steering column. Ill be slicing in to make ignition switch, fuel pump, lights.
Ive almost stripped the whole car. I still have to pull out the back and figure out how to remove the steering column. Ill be fixing the floor boards and then painting it all with rust stopper.
#54
