dual 11" spal electric fan install
Does anyone have a good step by step guide to installing a dual 11" spal electric fan setup on a 1972 350 manual with ac? I keep finding wiring diahgrams but most of the threads don't have pictures or they have been removed because of their age.
What are you trying to do....Install the twin fans set-up that is all together in an assembly and mount that to your factory style radiator or what????
I know about the twin SPAL fans ..but you are not giving any information on what it is going to be installed on.
I am assuming that you are removing the factory shroud and the fan on the water pump.
ARE you planning on having the A/C work also. It makes a difference in how the fans are wired up.
You WILL also want o make sure that ALL seals between the radiator and the radiator support are in good condition...AND...the rubber seal that goes on TOP of the radiator support is being used where it seals the underside of the hood to the radiator support as designed.
You more than likely will need to remove the radiator so you can get the fan assembly installed
I just did a 1974 with a new DeWitts radiator and it went in fine and wired it up using different relays because I prefer GM style relays.
It is not that hard but you can spend some time on it to make it look really nice..in regards to wiring harnesses and mounting relays and such.
DUB
DUB
1974 with a new DeWitts radiator & GM style relays
DUB
DUB
I just picked up Corvette Dual Radiator Fans, Electric, 11" Direct-Fit, 1969-1982
•Fits All 1969-72's With Original Copper/Brass Radiator Or Aftermarket Aluminum Radiator
•Kit Includes: SPAL Dual 11" Fans, 2 Mounting Brackets, 1 Hardware Kit, 1 Relay Harness, 1 Temperature Switch & 1 Controller (part # 50349)
From Ecklers. The goal is to eliminate the stock clutch fan and clean up the front of the engine bay. My radiator looks to be stock (Black and bulky). The kit i bought looks like the one you have in the picture above. I'm looking to get information on how to actually wire it up to my electrical system so it looks clean and doesn't create a fire hazard. I would like the 1st fan to run constant and the 2nd to kick in when the temp climbs. Any tips or pictures of how the wires are connected are what I'm looking for. Where is the best spot to connect the Power leads, where should i connect the ground, connect the temp sensor.... etc.. I can handle the mechanical side, it's the electrical that i always get hung up on.
Thanks for your help
Forgot to answer the other part of your questions. Yes, I plan on removing the factory shroud. I am also installing a Vintage AIR system/steeroids/spreader bar at the same time. So it will need to be setup to handle air conditioning. Ultimately I'm trying to clean up the engine bay, update to more modern parts and add a little comfort.
I'm not sure if I did mine right. I ran the fans off the back of the alternator. I'm thinking that the shorter the wire, the better. Plus you're coming right off the power source. The fans ground, on core support. I had to run a ground strap from engine to core support. I mounted my relays on the core support also.
How many amps do both fans pull? Might have to upgrade the alternator.
Rather than ground the fans to the support and the ground the support, tie the two ground wires together. Also, when I received my Dewitts fan already mounted to the rad, I found that the driver's side A arm contacted the fan. I had to R/R the fan assembly to the pass side.
Tie the two ground wires together makes sense, but where is the best place to ground them to for functionality and also aesthetics? I want a clean look without wires drooping in the engine bay. Also, where is the best place to connect the power? I've heard the altinator isn't the best option. Horn Relay? Direct line to the battery? Can it be taken to the fuse box?
I thought I could just ground the fans to the core support, because it checked good with a tester, but when I jumped the thermo switch, the relays just buzzed. Adding the ground strap cured the problem, so I left it like that.
Tim
brennano1:
I did not use the controller... so I would need to see it. I could not see it when I looked up the part number from Ecklers.
On Jim's Corvette (pictures above---THANKS JIM!!!)...a sensor was installed in the radiator to make the fans come on when needed. Also..if you look at the labeled relays on his firewall. One of them is labeled 'A/C REQUEST'...which makes the fans come on when he turns on his A/C...even if the engine temp is low and the sensor has not turned on the fans.
Wire it in as you wish...but I would NOT have a fan always running. That is my preference.
The radiator may need to come out so you can mount it.
I can help your when you get it ready to put in but I need a link to the controller and wiring diagrams or something so I know what is going on. The grounds and all that will be taken care of. It will be up to you to do it.
Also. I UPGRADED Jim's alternator to an 85 amp alternator (including all mounting hardware which is required) for a 1981-1982...and the new forward lamp wiring harness that went to the alternator ..I removed that wire and replaced it with a much larger gauge wire and custom made a better junction block to better distribute power. NUMEROUS HOURS of electrical upgraded and changes...and if you look close ..I chose to use GM designed relays so all of Jim's relays are all the same.
DUB
DUB
Tim:
This is a Derale setup. I had to thin the shroud by 1 1/4", to fit between the control arms, and rad.
I used 1 1/2" x 1/8" aluminum angle, top and bottom.
No wiring is done in this pic.
http://www.summitracing.com/parts/der-16831/overview/
It didn't look like the picture. The shroud was 2 3/4" thick, and hit the control arms.
http://derale.com/products/electric-...-header-detail
This is actual.
This is actual.
You could install these controllers.
Use 2, one to have 1 fan come on about 10 degrees after the first.
http://derale.com/products/electric-...s/single-stage
