Another mechanical oil pressure sending unit question
I have looked through the old forums, the internet and multiple catalogs with no luck. I junket the old truck motor that was in my 72 and replaced with a L82. The old motor had no gauges hooked up and the oil pressure gauge in the dash has the plastic tube for a mechanical oil pressure unit. Anyone know where to get one or do you just make one from homie depot?? I'm assuming this little 1/4 inch plug is where the unit should be located. Any info is appreciated.
