Idle mix affects entire Holley power band?
07-25-2014, 09:17 AM
Is there any impact, even small, on the A/F mixture over the power band with regard to the idle screw mix setting on your "typical" Holley?
07-25-2014, 09:28 AM
St. Jude Donor '05-'06,'11,'13-'14,'16,'18,'19
Yes mainly at cruise when on the transition circuit
Neal
07-25-2014, 10:50 AM
It might help you to understand that whenever you are in a high manifold vacuum situation, you're pulling fuel through the idle circuit.
Scott
07-25-2014, 11:42 AM
Idle
Thanks.
Appreciate the info. That's what I thought I'd noted in other discussions, but just wanted to be sure.
