Need a rear sway bar measurement
Can someone with a Vette brakes or even a stock sway bar take a measurement on how wide the rear sway bar is. Seeing if it will fit between my tires. Thanks
It is even with the tailing arms if that helps as I was recently rebuilding everything under mine. If you are running offset arms with deep tires then the tires will probably hit the sway bar.
Received 3,218 Likes
After some back and forth today with Dan from VS the stock bar won't fit unless I get out the heat wrench. His bar just won't fit with my current new exhaust. His setup is really nice I just don't want to mess up a brand new expensive exhaust system. So I think I will call addco in the morning and have them bend me up a custom slightly narrower bar and I may have to make some different mount brackets but what else is new. Nothing on this car has fit since swapping out to LS. Power so why should this be any different.
my bar is bent to 46 inches center to center
Good for you! Tomorrow I could give you my inside tire side wall bulge to bulge measurement if you would like. I have not looked into the Addco bars
My 79 never had the sway bar OEM.
If you or anyone else after you is interested I have a splined rear bar off my vintage racer project available, .875 diameter, 42-7/8 (44" wide counting the heims) wide with 11" arms, if the 11" arms are longer than stock they will reduce the stiffness of the .875 bar and if I remember correctly the heims mounted to the inside of the t-arm portion (the car came with a 5-link) instead of on top.
48 3/4 inches from inside tire bulges
