Spark Plug wire routing
i have a Moroso plug wire separator kit like this, Brackets attach to outter valve cover bolts
http://www.summitracing.com/parts/mor-72133/overview/
Its a a/c delete heater box. I got it from eBay . I removed my a/c and found the original box deteriorated from oil. The a/c delete box mounts the same as the original box but its much thinner since it does not hold the evaporator. The only thing that was a little tricky was fitting the blower resister . I've saw a few different ways to mount it , most are bottom mounted but then the wiring harness needs to be lengthened. Not wanting to cut the new harness I installed I modified the resister to fit on the top. I have some pics from when I installed it if you want to check it out.
I route my plug wires the same as they did from the factory (SBC).
From the plugs down, through the sheet metal shields on the block and back up behind the heads. Factory length wires work, don't need any fancy or expensive looms and I don't burn any wires. And yes, I have full length headers.
Pete
Morose spiral wires under the headers.
