Mystery Line C5 LS1
Mystery Line C5 LS1
I was poking around the motor just now and found this unattached line. It goes down and back and disappears near the headers and seemingly goes into the firewall - maybe. I can't see where it would connect but it seems solidly connected at the other unknown end.
There is a similar line to it connected to the bottom of the brake booster via a hard line. Both have black dots running along their sides and both seem to disappear to the same area in the firewall. Replaced vacuum line that wasn't removed? The other one seems to have a more 'hard' connection vs this nipple and also has a gold-colored canister which I suspect is a one-way valve while this unattached one is plain all the visible way back.
Is it a service line? Should it be capped off?
It runs, brakes and clutches fine.
Cruise-In IX Veteran
Definitely looks like a clutch remote bleeder. I have one on my C5 as well. As for the other line, I am not sure what it may be. You should post a picture of it in the C5 section.
Remote bleeder for your throwout bearing and the other that is attached to the gold canister is probably the supply line, gold canister being the resevoir.
