KYB vs Bilstein?
Thanks guys! Great info!
Brcmpbl-
Why bilstein sports?
Did u lower ur car?
According to Bilstein, sports r engineered specifically for lowered suspension systems. They improve their handling. If not lowered, sports will roughen the ride on a stock height suspension. They advise the best stock to control at stock height is the HD.
I do plan on HDs...but anyone try HD vs sports?
With stock height??
Thx
Ron
Brcmpbl-
Did u lower ur car?
With stock height??
Thx
Ron
I had KYB with the special valving for composite spring and never did think it was correct. Switched to Koni's and stiffened them up 1/2 half turn and the rear feels the way it should.
If you drive your car normally, I doubt you would notice the difference between gas-a-justs, and HD's.
Not all KYB's are equal, the gas-a-justs are MUCH better shocks than the GR2's. So, when people are talking about Bilsteins being much better than KYB's, they are talking about the GR2's.
I have had the OEM delcos with the F-41 suspension-steel rear spring and switched to KYB Gas A Just for the rear with the steel spring and the gas A Just were OK. In 1986 I put on a VBP 360 mono spring and kept the KYB Gas A Just-bad move. Way too bouncy. On the subject of KYB's, they are a tad better than mass market shocks-Gas A Just and GR-2's-don't think for a second, KYB's-both of them- are anywhere near a Bilstein, they are not-Not even close!
I had a set of KYB GR-2's on my 2001 Grand Prix and was extremely disappointed-They were way softer than the OEM Delcos. I totally don't buy the special valved Gr-2's for a monospring. The GR-2 is a mass market shock/strut and will never be a Bilstein. Last fall I put a set of Monroe Sensatrac Police/Taxi Struts from a 2001 Impala Police pkg car all around on the GP in place of the GR-2's and they have transformed the car-It rides and handles great.
In 2005, I switched finally to Bilstein HD's all around with the 360 rear spring and 550 fronts. I still felt the HD's were a bit too soft for my taste but a GREAT shock compared to the OEM Delcos, KYB Gas A Just, and I also had a set of oil Koni's in those 30 years as well. About 5 years ago I put on a set of Bisltein Sports in the rear only (the Sports are 30% stiffer than the HD's) and left the HD's with the 550 front spring since they are pretty stiff. The car rides, handles, and has great steering response-Its awesome!!! The ride is firm but NOT overly stiff-just planted and actually very comfortable. You would never know my C3 has a 360 spring, Bilstein Hd/Sports, 550 front springs etc. I often chuckle when I read folks want a 290 rear steel spring or 300 front springs-not the way to go with these cars. Karol on the forum was recently in my 78 L-82 and he could not believe how much BETTER my car rides than his stock base suspended 78.
I also have a spreader bar in front and EVERY C3 should have a spreader bar to tighten up the frame flex in the front. Three things to transform a C3 handing/ride:
1. Bilsteins-all around-your choice about HD's or Sports
2. Front Spreader bar
3. Competition Heim Jointed adjustable strut rods-NO BUSHINGS to flex
With the suspension above, custom blueprinted/rebuilt OEM steering box (by you all know who), 255/45/17 ZR ultra high performance summer only tires, and NOW the recently installed rebuilt L-82 355 roller cammed/AFR head engine, the car truly is a modern sports car. These cars can be made to modern standards-it just takes time, money and know how.
Hope that helps!
Hope that helps!
I run KYB GR-2 in front and KYB in rear. Installed in 2005... 9 years of street driving and handling is excellent. Very stable ride and they don't bounce like the tired Gabriels I removed. The car is not road raced or drag raced.
NOTE: Both front and rear suspension systems are in above average condtion on my L48. Makes for consistent and trustworthy handling.
Thanks guys!!!
Jbl82- Does the spreader bar help primarily w cornering? Weight transfer? Or basically just tightening up the car?
Pm too
Pm too
The spreader bar was noticeable immediately after I put in on the car and left the driveway. My road is relatively smooth but with some minor waviness. The bar stopped chassis squeakiness, made the suspension more responsive, tightened steering response and made the handling more precise/predicative. No noticeable change in weight transfer
There are two different KYB GR2 shocks for the rear. The first has standard valving and is soft and lacks rebound control when used with a fiberglass spring. The second, available from VB&P, has greatly improved damping. Neither is a 'feel every change in the road' shock, but the second gives both a decent ride while controlling the rear end so it doesn't keep bobbing up and down like the white KYB monotube shock did.
#33
Jeff...I read something that the spreader bar will not work with a BBC?
also must have electric cooling fans...good there...but ONLY on SBC?
R
R
#37
skip all the crappy non adjustable shocks. If you are cheap go with Koni. which are are only 3 position shocks or get the best like these
http://www.summitracing.com/parts/ha...model/corvette
#40
Thanks zwede!
VBP has some promising info on their site about the bar...waiting on an email.
Thanks for info on brands...I am going with Bilstein...not completely sure if HD or sports....
please see my other thread for my other part breakdown affecting my decision.
Thanks!
Thanks!
