Halfshaft U-Joints?
Halfshaft U-Joints?
Hi Guys,
I have my differential pulled while I'm doing some work under the car. I want to replace the u-joints while i'm under there.
Are these the ones I should buy? I'm not sure which are correct. It says all 71-79 driveshafts, but only 80-81 halfshafts.
I have a 1978. Are these the u-joints I need for the halfshafts?
https://www.vansteel.com/index.cfm?f...p=3026&ID=3193
Thanks.
Thanks.
Hi Guys,
Thanks.
Thanks.
i paid 200 each for custom made half shafts. they will handle a bit more power than the factory ones ever could .
PST out of Tampa. they weren't in stock but they made me a set balanced painted everything. and overnighted them to me. veeeerrrrryyyy nice job.they do aluminum too.
Cruise-In IX Veteran
I did not use those for the halfshafts. My 71 halfshafts used a 5-799X ujoint. The 5-790X ujoint would we the driveshaft for a 71-79 regardless of transmission. The 70 and earlier C3 would use the 5-790X (1330 series) joint with a turbo 400 and a 5-785X (1310 series) joint for the manual transmissions.
Yeah, here is the correct halfshaft u-joint for a '78.
The 5-799x, 1350 series u-joint.
http://www.vansteel.com/index.cfm?fu...p=3026&ID=1966
But I think the 5-799x is old and was replaced with the 5-1350x, can anyone confirm?
1 Post
Ok so which one is correct? Everyone gave a different answer and all of them are not showing correct when I do a compatibility check. When I search my 78, these are the ones that show they fit:
Spicer 5-213X U-Joint Kit
I am looking for a non zerk one. Any ideas?
By the way, Duntov Motors looked to be the only vendor that offered halfshafts w/o u-joints, but it seems like they've taken my money and run. They charged my credit card and I've received 0 communication.
Does any other vendor sell halfshafts without the u-joints?
5-1330X non grease zerks
http://www.drivetrainamerica.com/p-1...nt-5-790x.aspx
Well, I bought the 5-1350x's. I don't know if they fit yet as I destroyed a halfshaft removing the old u-joints.
Ok…a little more research and it looks like the 1350x's are correct for half shafts and the smaller 5-213X and 5-1330X are for the drive shaft. The compatibility check was only figuring the drive shaft and not the half shafts.
A 5-213x is a greasable 1330 size ujoint
