1971 Brands Hatch Paint Match
My 71 is going to paint soon, it looks like I will be using DuPont two stage with the original Brands Hatch Green color code. Has anyone sprayed this paint and does it represent the original BHG color?
Thanks, Kevin
Thanks, Kevin
What is the DuPont color code you are considering?
I'm just doing research, should be about a month before the paint goes on. I was assuming DuPont would only have one number for Brands Hatch Green. I was also wondering about the metal flake, would there only one option for metal flake in this color? How would I know if the metal flake is correct?
I've never seen this car with paint on it and never seen a BHG Vette in person so I'm kinda shooting in the dark. I'm also assuming with a standard clear coat the sheen will be glossier than the factory lacquer.
Kevin
Kevin
I just want to mention something. I have the brands hatch green on my car. It's still original, but needs to be re-painted. My buddy owns a body shop and showed something exactly the same. It's called Clover Green Pearl and made by Honda. I have been using the touch up version and it is spot on. The flake is awsome as well in it. Just thought I would share.
Received 1,470 Likes
Cruise-In II Veteran
Look for auto body supply house in your area that sells Dupont. Stop in with BHG paint code and have them look up formula in computer. I am not sure about the older colors but alot of the newer ones have different variations on the same paint code. Body shops use variation paint chips to obtain closet match daily. I have seen newer paint codes with 7 different variations to the same color and code.
It is not uncommon to have a slight variation in color from one paint manufacturer to another. For example, I was told by a Vette restoration shop that they only use Sikkens paint when spraying Ontario Orange. They claim that it matches factory paint work as far as color.
This is the kind of info I was looking for.....I want it in a two stage but still color correct for 1971 BHG. This is even harder for me because I don't really know what it supposed to look like.
I guess I'll take a shot in the dark and use the manufactures mix. Paint "color" is tricky because the color is really a property of the light you are under, not the paint itself.
Kevin
Kevin
Kevin
Kevin
If so, that is not the case. The dist. will mix the paint on site as per the formula just as a body shop would if equiped with a paint mixing machine. That is why it is important to buy extra paint on an overall and mix it all together, then use what you need and save the rest in a cool dry enviroment. Human error is at play when mixing paint. A little extra of one tint can throw the color off.
Why don't you buy a quart and shoot a test panel and compare it to one of CF members cars. Maybe someone has a BHG Vette in your area. If your going to Carlisle in August bring it with you. You will sure find BHG cars on display.
The problem with mixing 4-6 ounces is that just a miniscule error in the amount of any added tint color can throw the formula [and color hue] off by a significant amount. You might be better off mixing the amount you need to the best formula you can find. Then, shoot a small panel and compare it to an actual factory paint job. Minor adjustments can be made to the paint, if you plan it well....and if necessary.
