Question and suggestions for ignition coil and module
Old 06-01-2014, 06:13 PM
Hals76
Hals76's Avatar
Default Question and suggestions for ignition coil and module
I am trying to do minor horsepower improvements without spending lots of money. I am trying to do most of the work myself; I am not a mechanic. I have recently put an ignition advance kit in my HEI distributor. The car runs faster! I am thinking about putting a MSD coil and module in it. Will this increase horsepower and smoother idle or am I wasting time and money or is there a better idea? Will I have to redo the timing if I install either of the two parts. What do you think?
I have the original 350 V-8 (L-48), Dewitts aluminum radiator, headers with dual exhaust and Magnaflow mufflers. The Qjet was recently rebuilt.
THANKS EVERYONE!
Old 06-01-2014, 07:30 PM
REELAV8R
REELAV8R's Avatar
Received 1,034 Likes on 852 Posts
With stock motor your stock module and coil will work just as well as an MSD coil and module.
Old 06-01-2014, 07:33 PM
Mike Ward
Mike Ward's Avatar
A hotter spark will not give you more horsepower.
Old 06-01-2014, 07:53 PM
dugsgms74
dugsgms74's Avatar
In my experience the advantage w/ the MSD stuff is if you buy the entire distributor due to its better/more consistent advance curve.
To Question and suggestions for ignition coil and module
Quick Reply: Question and suggestions for ignition coil and module
