Pace Car style front spoiler...will help cooling??
Your extension looks a lot nicer than my home made version.
If installing a 3 piece spoiler, then you must remove the original piece.
After installing an aluminum radiator, change of thermostat, and replacement of shroud seals, I did notice a difference after then installing a 3 piece pace car spoiler. The car ran cooler at high way speeds.
Scott
I like the black spoiler
Back in the late 70's GM offered a "Lower Radiator Extension" that could be added to the factory poly chin spoiler. It added about 2" to the bottom of the spoiler and was intended to draw additional air into these cars to assist in cooling, especially with A/C...
It is made of multi-ply "mud-flap" type material and comes with two metal reinforcing strips that sandwich the original spoiler between themselves and the extension. Smooth headed bolts go through all three pieces of material and have nuts on the backside. They were very inexpensive, easy to install and very durable and relatively inexpensive to boot.
GM offered them over the counter until about 10 years ago. I believe that LICS still carries them in their catalog. If you obtain a few strips of the material, it would not be difficult to fabricate one. Oh, and they do work to lower temps...
Good luck... GUSTO
Good luck... GUSTO
I first learned of the radiator extension about 1980 from a magazine article and bought one for my 1977 to add a bit more dimension to the front end. It added a lowered appearance to the front end without actually lowering the car and because of its flexibility was curb friendly, all for the princely sum of about $20! Later in 1988 when I bought the '73 in the picture it was one of the first things I added to it. The effect was the same and it had the added benefit of masking a slightly damaged spoiler.
LICS is Long Island Corvette Supply, http://www.licorvette.com/, a well established 63-67 Corvette parts source that enjoys a great reputation with many C2 aficionados. I believe that they carried it at one time, but can not now find it in their catalog. However I did find it in Willcox's catalog http://willcoxcorvette.com/product_i...=27465&osCsid=
It says that the retainers are not available, but they are simply two (one for each side, #6 in the pic) flat pieces of about 1" wide sheet metal painted black that act as reinforcements on the back side of the stock plastic spoiler (#3).
Good luck... GUSTO
I got the plastic piece awhile ago cuz car would overheat and the small chin spoiler made a difference when I added the indy style one piece connected to the plastic and haven't had it go up over 200f on a hot day. And it looks cool.
The ORIGINAL and bestest
Toronto Events Coordinator
This is exactly what I have been looking for my project...thanks
http://forums.corvetteforum.com/c3-t...ica-kinda.html
So that's your car with the spoiler. Very nice where did you get the spoiler and what did you cover it with? Also did you see a difference in the stability of your car?
#34
I covered it with 3M Di-Noc carbon fiber vinyl wrap, it is very realistic in both looks and feel.
I did notice a difference in stability at speeds above 120mph.
#35
Received 3,138 Likes
Not wanting to hi-jack but what does that spoiler (the new one you put on) look like where it meets the wheel well lip? Does it wrap around at all?
M
M
#37
Hmmmmmm, that might be close to what I've been looking for
Thanks, if you get a chance to snap a pic of the back side where it goes up the edge of the well I'd appreciate it.
(Can't even seem to get out to Uxbridge as a passenger so far this year)
M
M
#38
The factory designed PC air dam does improve cooling, by increasing pressure on the face of the radiator while decreasing it below the car aft of the rad. However, not all PC style air dams are equal. The factory designed PC air dam, unlike at least some aftermarket ones, includes an integral isolator panel to keep air from leaking back beneath the car behind the dam and ahead of the radiator. With air dams that don't include the isolator, you must install an isolator such as the one illustrated in GUSTO14's previous post to avoid this being an issue.
As for other aerodynamic benefits, I don't have hard numbers to back up findings made by the sensitive instrument on which I sit, but the PC aero kit (front dam & rear spoiler) most definitely kills lift at higher speeds, and almost certainly produces downforce. Factory claims back in the day were of approximately 15% improvement to the drag coefficient w/PC aero kit vs w/o.
For those concerned with very high speeds, one fly in the ointment I've found with the factory PC air dam is that the center section requires some form of bracing to avoid the onset of rapid oscillations (yes, I mean flapping up and down) and/or folding under outright (BTDT). This problem is fairly obviously due to the factory's concern with damage from curb strikes, and thus the flexible material from which it's made. While a full-blown, extended splitter with struts may not be practical for everyone to consider, it might be possible to get by with a hidden backing panel of some sort, as long as it is sufficiently supported for the speeds in question. (For my needs, next stop is doing a genuine splitter.) Not sure what measures were taken on THE actual Indy Pace Car used in '78 for the 500, but they had to have done something to combat this very real problem...
Anyway, although the PC dam/spoiler package doesn't necessarily represent the pinnacle of C3 aero development, it is nevertheless a sound design, as long as those nearer the hardcore end of the scale respect the shortcomings of its execution. Oh, and Captain Obvious demands I advise that if you do happen to like traveling fast, you should always make certain that any front dam is offset by a sufficient amount of spoilage out back. It may be meaningless at a pedestrian pace, but I've had a rear wing fail at speed (on track), and believe me aero imbalance is NOT your friend. My $.02, which I hope covers something not already discussed to the OP's satisfaction.
TSW
TSW
#39
http://lateral-g.net/2013-good-guys-...oss-final-run/
