82 CFI with aftermaket cam?
I have a Renegade intake that I'm ready to install but as you know one thing leads to another so I have decided to replace the heads with Edelbrock aluminum along with the cam. I have decided to go with Comp's XFI series and it's between the 252 and the 260XFI H13. They both claim excellent for Crossfires so has any 82 owners use either one of these cams??
I installed the Comp Cam's XE249H with Trick Flow® Super 23® 175 Cylinder Heads TFS-30300002, Regegade Intake Manifold and Magnaflow hi-fo Catalytic (I live in California). Also installed 3.73 gears. What a difference!!!!
I tried both the COMP Cams 1.5 and 1.6 Rocker Arms and I'm not sure which I like best. The 1.6 moved the power curve to the top end whereas the 1.5 keeps it mid range.
If you get the cam/intake swap done and it runs bad, you can always find someone that can recalibrate the PROM so the ECM can handle the added parts.
No computer issues at all. Just install the new stuff, set timing to factory specs, adjust the throttle bodies (including the TPS) and enjoy. With the combination I have, you'll now burn rubber in 1st and 2nd gear. NICE!
At 050 the XE249H is only a little more aggressive than the stock cam. I suspect that it makes up for it with ramp rate as most aftermarket cams do. It has about 0.030" more lift on each lobe vs the stock cam (at least the 84 cam I looked up)
The XE is a flat tappet, the XFIs are rollers.
Since you're doing heads, I'd probably do the XFI260. I think you'll be happy with the torque on any of them. The 700R4 has a low first gear to get you rolling and once you're rolling you'll be golden!
I'm putting the XFI268 in my engine that's being built right now, but it's carbureted. I probably won't get to drive it til the end of June, though, waiting for a number of parts to come in.
I did not realize the XFI are rollers, I spoke with a Comp Cam tech today and he did not mention that. You can swap a flat tappet cam for a roller as long as you have roller lifters right? So them I'd just get the cam kit. I thought roller cams were expensive and for the cam and lifter kit from Summit it was only $199.97 that's why I figured it was a flat tappet. So is that right or not?
there's more than just the lifters. you need a cam button and possibly a stronger timing cover. then you have to adjust cam endplay. there's a little more to it than just throwing in cam in lifters unfortunately. I've been debating going roller or stay with flat tappet. I'm not really sure roller is worth it in a computer car, because you can only go so big anyways.
Comp sells the XFI cams in flat tappet and roller. The part number you gave is for the flat tappet version. I've been kicking around the idea of doing just what you are proposing, but I can't shake the LS bug either, so I'm waiting to see which side wins out. I'll be watching your progress to see how it works out for you and factor that into my final decision.
I have ordered my parts but the cam won't ship till June 3rd, no big deal that gives me time for the removal and at least I can install the heads.
There are XFI variants in factory roller, retro-fit roller and hydraulic flat tappet.
Are you doing a total rebuild or just the cam and heads? If I decide to go the same route you are going I think I will do a total rebuild of the engine. Either way I'm looking at a bit of downtime. A third option is a crate engine (long block) and adding a Renegade and a cam. Decisions, decisions...
Yes indeed decisions. I'm not doing a rebuild, doesn't need it and I bet I only put less than 2000 miles a year on it. I'll wait and see what the pistons look like but no just the heads and cam along with the Renegade. I already had the Renegade on once and holy crap what a difference just that alone.
Yea they are in business. They have a new company making them called Eddie Motorsports in Calif. They sell out quickly so you need to watch he DCS website.
Just finally installed a Comp Cam and in the paperwork they reconmend using break-in oil. I have never done that before so what do you guys think? I was just gong to pour in 10W30 Castrol and start er up. I do however have all the lobes fully lubed with the supplied red stuff.
