Broken Wheel studs
Old 05-18-2014, 10:26 PM
68Thunder427
68Thunder427's Avatar
Default Broken Wheel studs
While taking off my rear wheels two wheel studs on the driver side broke off. Do I have to take the entire trailing arm bearings and spindle apart to replace them?
Old 05-18-2014, 11:30 PM
Mooser
Mooser's Avatar
Received 3,138 Likes on 2,069 Posts
1-3/4 stud can be snaked in, 2" stud can be put in if the head is slightly ground or the shield is trimmed
http://forums.corvetteforum.com/c3-g...stud-bolt.html
Old 05-19-2014, 09:55 AM
gjohnson
gjohnson's Avatar
When I replaced a broken lug on the front I put the rotor on,put the new lug in stacked bunch o washers on a couple of studs and put the lugs on to hold rotor in place. Then did the same on the replacement. Pulled it right in! Good luck!
Old 05-19-2014, 03:26 PM
68Thunder427
What is the correct size stud that I need to get? What is the correct Under Head Length (UHL)? 7/16" - 20 RH x ____? UHL .480 knurl
Old 05-19-2014, 11:00 PM
68Thunder427
Bump...No help here guys and i do not want to cut the dust cover or grind the studs..So is my answer to pull the trailing arms completely apart?
Old 05-20-2014, 02:34 AM
69Vett
69Vett's Avatar
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
yes, those are your options.
Choose wisely !
To Broken Wheel studs
Quick Reply: Broken Wheel studs
