'81 rear pinion seal replacement
Old 05-15-2014, 10:22 AM
qwank
qwank's Avatar
Default '81 rear pinion seal replacement
is pinion seal replacement on these aluminum diffs the same as 99% of the cast iron GM diffs out there?
measure turning torque, mark the nut, count the threads, recheck turning torque when done? I'm going to be pulling the diff out soon to reseal it, and want to make sure there's nothing special about this one.
Old 05-15-2014, 12:07 PM
hugie82
hugie82's Avatar
Good question?
Old 05-15-2014, 01:07 PM
tracdogg2
tracdogg2's Avatar
No, quite different. 80-82 uses pinion shims instead of a crush sleeve. Mark the pinion nut and the pinion. Re-tighten the nut to align the marks. Be sure the shim between the bearing and the flange is there before you put the seal in.
Mike
Old 05-15-2014, 03:57 PM
qwank
qwank's Avatar
Thanks Mike
Old 05-16-2014, 10:24 PM
0Willcox Corvette
Former Vendor
Willcox Corvette's Avatar
Received 1,813 Likes on 1,458 Posts
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Mike
The dana rear end is easier and pretty much fool proof.. (with a emphasis on "pretty much"). We had a customer install it backwards three times before he brought us the car. Yes, the seal can go in backwards but it will also leak... So make sure you have the seal installed the correct way.
Old 07-05-2015, 01:59 AM
SciVette
SciVette's Avatar
Alright Wilcox, you tease... Can you explain/describe correct versus backwards on this seal, so I don't follow your customer's example?
To '81 rear pinion seal replacement
Quick Reply: '81 rear pinion seal replacement
