Dakota Digital VHX install
Old 05-20-2014, 01:41 PM
hyteck9
hyteck9's Avatar
Originally Posted by AboveTheLogic
Want to rebuild mine while you're at it?
NOPE.
haha... and you are foolish to ask before seeing if I can even get mine back together!
Old 05-20-2014, 02:45 PM
donnie1956
donnie1956's Avatar
Originally Posted by hyteck9
Started pulling the engine, decided to redo that too!
Amazing how much gets undone with a "while your there". I did that with a broken exhaust manifold bolt and ended up with an LS engine.
Luweegy (11-22-2019)
Old 05-20-2014, 02:57 PM
hyteck9
hyteck9's Avatar
Wow, an LS conversion?
Nicely done.
I'm not going that far. I'm trying the Edelbrock RPM Power Package.
Besides, I like having at least one carbureted engine in the garage.
Old 05-23-2014, 09:25 AM
hyteck9
hyteck9's Avatar
Engine is out. Also bought the zip-corvette total suspension kit.
Anyone want pics of this build too, or are we all experts on suspension and engines?
Old 05-23-2014, 10:49 AM
AboveTheLogic
AboveTheLogic's Avatar
Pics, always!
Old 05-27-2014, 01:31 PM
hyteck9
hyteck9's Avatar
Pics, always!
OK, I am going to start a new thread for the engine rebuild and suspension, as it is off-topic.
Old 06-02-2014, 05:59 AM
dembo
dembo's Avatar
Hi,
Thank you for the write-up.
I'm planning a LS swap and am considering these gauges as well as I don't want to mess with Abbott boxes, different trans housings etc. As you I really would like to retain the red lenses in the center cluster (headlight warning and door ajar in my case).
How did you design yours to retain the lenses?
Drill the rear cover of the new VHX and clip on the existing lamp socket, reuse (cut, extend) the cardboard tunnels to seperate the light?
Thanks,
Nick
Old 06-02-2014, 07:36 AM
hyteck9
hyteck9's Avatar
Thanks,
Nick
HI Nick,
Nothing that complicated. The kit comes with "blackout pieces" that you have the option of laying in to prevent the light from shining threw, I just didn't use them on the one side that has the "gen" light.
Old 06-03-2014, 03:02 AM
dembo
dembo's Avatar
Thanks for the heads up
Nick
Old 06-13-2014, 12:13 PM
hyteck9
hyteck9's Avatar
You are welcome!
Old 08-23-2015, 03:28 PM
dembo
dembo's Avatar
You are welcome!
Some additional photos from my dakota digital VHX install
I'm running into the same small issues as Brian.
They still don't provide a fixation support for the tach to a A/C dash pad.
Idea nr 1 stolen :
As mentioned before the kit has block off plates for all the center console lenses. I used one for the 'fasten seat belt'. A) it's a natural reflex to wear it and B) it doesn't work as the seat belt interlock has been eliminated. I did wanted to keep my door ajar and headlight lens. Time to Dremel. I used the metal part from the original bezel so I don't have to wory about diameters and material thickness for the lamp sockets. Scrap ABS was used to close the box around the lamp to make it 'light tight'
This is the speed transducer to convert the mechanical rotation to a electrical speed signal.
Spend the last two days wiring but ran out of time. It's a very nice kit. I chose the black alloy with white backlight in km/h. (Mandatory that the gauge face shows it)
I'll post some pics next week when I'll be testing
Nick
Old 03-13-2016, 08:09 PM
Mcjoshin
Mcjoshin's Avatar
I'm considering these gauges. Happy with it so far? My understanding is that you basically replace all of the sensors and wiring with new stuff right? How difficult was it to redo all of that?
Old 03-14-2016, 08:30 AM
  #33
hyteck9
hyteck9's Avatar
The sensors were easy. The hardest part is removing the dash and cleaning up all the wires... most of which you won't need anymore.
Just take your time, and label everything.
Old 03-14-2016, 11:55 AM
  #34
dembo
dembo's Avatar
Very happy, all is working correctly, almost no battery drainage. I now notice that I'm running too cool (160F)
As Brian said, removing the dash and the small issues mentioned above during install aside, it's a very easy installation.
I went with the back face, white leds version.
Nick
Chappie (12-09-2016)
Old 04-26-2016, 02:00 PM
  #35
SLBelt
SLBelt's Avatar
Hytech, I'm looking to do this as well. Great post and thanks for all the time to show us this. However, I can't see the pics in part 1. Were they taken down?
Old 10-17-2016, 10:25 AM
  #36
SLBelt
SLBelt's Avatar
Hyteck9, You mentioned this comment about the Tach Filter:
NOTE: We realized the tach filter near the distributor was preventing the control box from picking up the ignition signal for the tach and bypassed it.
Can you elaborate on what this is (part of the kit or existing part in car)? I'm starting my install next week and this looked pretty critical to understand.
Thanks!!!!
Old 10-17-2016, 10:37 AM
  #37
hyteck9
hyteck9's Avatar
It was an existing part of the car. It dropped the inductance to correlate with the factory gauge ohms rating.
We simply didn't use it.
(Looked a lot like a isolation transformer.)
To Dakota Digital VHX install
Old 12-09-2016, 10:12 PM
  #38
Chappie
Chappie's Avatar
Nick
Hi Dembo. I am considering the black face/red numbers gauges for our '79, but those white numbers look really good. Can they be dimmed with the headlight switch or is the dimmer switch on the website a must.
Chappie
Old 12-11-2016, 09:31 AM
  #39
dembo
dembo's Avatar
Hi Chappie,
The dimming doesn't work with our headlight switch so yes you'll have to use their switch. On the other hand, the light intensity can be changed from the menu (both day and night time). I only set them once and never feel the need to change the setting.
Nick
PS If I woud do this again, I'd wait for the new HDX version (when it comes out for the Corvette). You can see it them on the Camaro page http://www.dakotadigital.com/index.c...od/prd1042.htm
Chappie (12-12-2016)
Old 12-12-2016, 05:29 AM
  #40
Chappie
Chappie's Avatar
Hi Chappie,
Nick
Ok, thanks. I looked at the HDX gauges, but didn't spend much time looking at them since I didn't see them listed for our car.
Right now we're trying to decide on whether to go with white numbers or red numbers. The red would look pretty cool since the interior is red.
Chappie
Quick Reply: Dakota Digital VHX install
