1979 C3 Engine Identification
Old 04-29-2014, 12:27 AM
Majer3rd
8th Gear
Majer3rd's Avatar
Default 1979 C3 Engine Identification
Hello,
I have acquired a 1979 Corvette L48. I was checking the engine to see if it was number matching but cannot find the partial VIN code on the block near the engine code stamp. The engine code stamp is V0621TJC, which I see TJC is a C20 to 3500 truck engine. There is no VIN code on the area where the engine code is stamped. The casting number is 3970010 which is a vague number in that it can be from 69 to 79 in a car, truck, or van.
How do I tell if this engine is original to the car or if it was a swap?
Old 04-29-2014, 07:04 AM
BKarol
BKarol's Avatar
If the suffix is TJC then it is a swap. 79 suffix codes begin with a "Z" and not having a partial vin says it all.
Old 04-29-2014, 09:27 AM
Mike Ward
Mike Ward's Avatar
That's exactly what it is.
Old 04-29-2014, 11:15 AM
Majer3rd
8th Gear
Majer3rd's Avatar
Thanks for the verification.
Well then, its clearly not a numbers matching car. I was going to decide on rebuilding the motor and since its not matching, I will swapping it with a 92 Camaro G92 motor and tranny or rebuild it. Since it is an l48 car and not a l82, this could be a good thing if it is a 4 bolt main block. Is there a way to determine this without dropping the pan?
Old 04-29-2014, 12:32 PM
Easy Mike
Support Corvetteforum!
Easy Mike's Avatar
Received 1,469 Likes on 1,248 Posts
Cruise-In II Veteran
...Is there a way to determine this without dropping the pan?...
That will take care of any guess work.
FWIW: you can build a nice two bolt engine. 4 bolt is not necessary for a driver.
To 1979 C3 Engine Identification
Quick Reply: 1979 C3 Engine Identification
