82 corvette single din modern stereo install
Cutting the original dash was very nerve racking but it went smooth! Measure 8 times and cut a little at a time. Then file fit.
wiring adapter from a mid 80s truck worked prefect but a few wires were different colors. Ign power and antenna. All the speaker colors were the same. The best part, no cutting on the original car harness!
I had to cut the two wire clip off the original stereo for the power antenna power and tape off the back light dimmer wire is not used on new stereos.
All tucked in except my FM antenna booster. That will just slip in behind the carpeted sides of the console. Perfect fit, I don't even need the little bezel that snaps in to cover the metal edge of the stereo frame but I did use it. Gave it a nice finished look!
I purchased a used center stack just in case it wanted to return to stock. The modern blue tooth pandora DVD GPS ect... really makes for a nice convenient ride now! No more wires and plugs with tape deck adapters.
I rarely document my projects but this time I actually did....so I share
Good job I've thought about doing a pop-out like that but don't know that I'd like to cover my gauges. I guess if everything is working ok then you wouldn't have to keep an eye on the gauges...
I usually leave it closed. It has a remote control or there are button on the face for basic functions. So it remains closed unless my daughter wants to watch a DVD.
do you have the trim ring for the radio?
With it open, I have a good view of the Temp and Gas gauge but I'm an oil pressure hawk, so I keep it closed most of the time.
Does any body know how they down load the GPS into these stereos? I bought it at BestBuy and I thought it already had it installed but it says GPS ready....
I don't mind spending a few bucks for it but I wanted to know if I have to pull it back out or it's just a plug in thingy???
Maybe your model works the same way?? Hope this helps.
