1973 vette door panel removal
Old 04-21-2014, 07:06 AM
USMC1371
Cruising
USMC1371's Avatar
Default 1973 vette door panel removal
Could somebody give me a detailed how-to on removing a 73 drivers door panel without messing it up?
Old 04-21-2014, 09:56 AM
GreenDream
GreenDream's Avatar
I can't keep you from messing it up, but the procedure is quite simple. Remove the clips holding the lock **** and the window crank if not power windows. Remove the 2 hidden screws holding the door pull on. Remove 2 screws from the top outside edges. Remove the bottom screws in the clips on the door edges.
Pull away from door and push it up to free it. If power windows, unhook wiring harness and your are free.
Quick Reply: 1973 vette door panel removal
