Oil Pan Gasket Problem
One-Piece Oil Pan Gasket Problem
Bought a Moroso 1 piece oil pan gasket and can't get it compressed enough to get any of the bolts in. If i push it down on one side, the other side pops up too high. Do you normally have to get longer bolts when using these gaskets?
http://www.summitracing.com/parts/mor-93150
I've seen some one piece gasket "kits" that come with longer bolts.
One of the reasons I stayed with old style gaskets.
Also from Summit......
http://www.summitracing.com/parts/fe...510t/overview/
There are two different thicknesses for the portion of the seal that runs between the oil pan and timing chain cover. I had leaks because i needed the thicker gasket and had the thinner one. You could potentially have the opposite situation happening. My experience was with fel-pros
Thanks guys - the pan I have requires the thicker gasket. The only thing is, I feel like there is too much gasket material on both ends that will prevent the sides from making a good seal. I wish the Moroso came with new bolts like the Fel-Pro - both are the same price now at Summit.
cagotzmann - do you remember what size bolts you used?
But a stud kit from summit.
