78 l82 de-smogged by bubba
I was told the vacuum advance is all jacked up by an old gear head that pointed out the advance was affecting my idle, that I wanted port vacuum but it was still running off manifold vacuum... Does anybody here know what to do or how to figure out what to do... I keep discovering more weird stuff with this car... Any recommendations on brands for the new distributor/coil?
contact Lars and get his papers for distributor set up. he suggests ( and most here agree ) manifold vacuum is what you want , if your purpose is to have a good running car.
You want manifold vacuum for best idle quality and off idle response.
You just need a can that is rated low enough to not oscillate in and out while at idle, that will make the idle unstable because it is advancing and retarding the timing when it oscillates.
Willcox (forum vendor) has an emission hose schematic that is color coded for an 78-82 L82. Print a copy that trace your hose connections..all! See where they are routed and set according to factory specifications than determine how its running and what to do next.
Correct for 78 and 79 L82, not for L48s.
