Removing Left Kickpanel Vent Door
G'day All,
I have to remove the left side kick panel vent door, as it's not operating correctly. Are there any pit falls that I need to know or advice that you can give that will make the job easier?
Thanks in advance,
Mark
Thanks in advance,
Mark
If I recall correctly, there is just one screw holding the kick panel up under the dash... you have to squeeze up into the foot well to see it. And the kick panel is tucked under the door sill so the sill has to come off as well. Very easy to remove the kick panel if the screws holding the door sill are not rusted/frozen like mine were.
Received 1,470 Likes
Cruise-In II Veteran
The only functions of the door are opening and closing. A bowden cable does that from the Vent **** on the console. You may not need to actually remove the door to get it opening and closing again. For factory air cars, there is no left side door.
If your door isn't sealing correctly when closed, you may want to replace the seal. The door consists of 2 oval shaped pieces of sheet metal riveted together with a piece of foam in between. Foam and rivet rebuilding kits are available, or you can purchase hardware store rivets and use 2mm black craft foam sheets. If you're not trying to maintain originality, you could use screws instead of rivets.
Pop-rivets make that job easy. Get craft foam at Michael's or HobbyLobby craft stores. (8"x10" sheets of black 2mm thick foam)
As mentioned, if the door is not functional, the Bowden cable could be rusted tight (inside the cable sheath), the mechanical actuator could be damaged (at the control head), or someone could have glued the door closed (???). Check condition of door and mechanism at the door first. THEN open up the console to check the rest of it.
The vent door is held to the car by two pins that it rotates on. One pin is fixed and the other is spring loaded, so that the door can be removed. The lower pin can rust into it's pivoting hole and freeze the door up. Been there, done that! Lou.
Thanks to everyone else for their advice as well.
My vent door must have been siezed up for a long time, as a previous owner(bubba) had stuffed a piece if rag in at the top of the vent/drain shaft to stop the air flow.
