1972 LT-1 engine question
Old 04-19-2014, 05:13 PM
thomaswat
thomaswat's Avatar
Default 1972 LT-1 engine question
I know that the '72 LT1 was rated at 255hp., but I've been told that they actually were a lot higher hp but lower rated due to insurance regulations. Can someone tell me what was/is the actual hp output. I'm trying to find out how it would compare to a 327cu. or 350cu. engine w/350hp. Would the difference in say 0-60 or the quarter mile times be much different with all things equal ? The '68 vette I'm interested in with the '72 LT1 isn't local so I can't drive it to compare, and would appreciate any thoughts.
Old 04-19-2014, 05:35 PM
Alan 71
Alan 71's Avatar
Received 2,878 Likes on 2,515 Posts
Hi T,
The 70 LT-! was the stunner at 370 GROSS horsepower.
The 71 LT-! was rated at 330 GROSS horsepower, one of the biggest differences was a sizable decrease in compression ratio.
The 72 LT-! was rated at 255 NET horsepower, but was basically the same engine as the 71 LT-!.
If it's a real LT-! engine, even from a 72, it's quite a nice sb factory motor.
Lot's of people claim to have an LT-! engine because the engine in question was in a garage next to an Lt-! once. Seriously… many claimed LT-! engines don't have the Lt-! parts.
The suffix code on the engine stamp will at least tell you what this engine started it's life as.
Regards,
Alan
The 350/350 was rated in gross horsepower so you can do the math to see how it would compare to the 72 LT-!.
Old 04-19-2014, 09:38 PM
Solid LT1
Solid LT1's Avatar
Like Alan has already covered how the motor was tested on the SAE dyno test was the main difference in a 71-72 LT-1. Owning both a 70 and 72 LT-1 the big difference is in bottom end torque and you will find that it is quite common for a 71/72 LT-1 to have been ordered with 4:11 gears by a dealer who was savvy enough to know the low compression was going to hurt performance. Hot Rod did a quickie 1 page test of a 72 LT-1 and actually coxed a 13.96 second 1/4 mile ET but not the 102 MPH trap speeds you will commonly see in a 70 LT-1. I had that issue years ago but haven't been able to locate it in years. The 71/72 LT-1s performance can be quickly upped with substitution of the crappy open chamber heads and when I wrenched in the 70s we commonly swapped 292 " turbo " heads onto these cars with great results.
Old 04-19-2014, 10:05 PM
LT-1 kid
LT-1 kid's Avatar
the 71-72 Lt-1s were a nice motor, would out perform any stock 327, but not the 69-70 350-350hp motors. had all 3, if you what real good power go BB.
Old 04-19-2014, 10:37 PM
7T1vette
7T1vette's Avatar
Received 2,713 Likes on 2,271 Posts
'71 & '72 LT-1 engines were lower compression than the '70 engines and I believe the cams were a little less agressive. The 'redline' RPM rating on the '71 and '72 cars was specified at progressively lower numbers. That doesn't mean that those engines wouldn't wind higher than 5800 or 5600, respectively; rather, GM specified those RPM's so that the rated HP would be lower BECAUSE of insurance 'issues'.
The '71 & '72 engines were essentially the same...although rated with different methods (Gross vs. Net power); but they weren't up to the likes of the '70 LT-1 engine.
Old 04-20-2014, 11:00 AM
thomaswat
thomaswat's Avatar
Thanks for the responses, however they lead me to ask another question and that is, why is there no mention of a '68 327/350 engine ? Is there a major difference in its performance vs the others ?
Old 04-20-2014, 11:20 AM
Lt1er
Lt1er's Avatar
TQ is the key and not some questionable HP numbers. TQ and ci run hand in hand, so the 327 with all equal parts will fall behind the 350.
The highest HP small blocks of that era are more fiction than fact when it comes to performance. Myth busters........ I have a highly improved .030 overbore in mine.
Like somebody said above the big block higher hp models or 454 are the way to go for performance
Old 04-20-2014, 12:02 PM
7T1vette
7T1vette's Avatar
The '68 327/350 hp (L-79) was a very nice engine. It was the basis for the L-46 and following LT-1 engines. If that engine and the L-46 were set up perfectly and put in vehicles that were tuned specifically for them, I'm not sure which would win a 1/4 mile drag race. The L-46 would have more torque; but the L-79 would wind farther with a longer power band, and likely have a bit steeper rear gear in its car (which would balance with the better torque of the L-46).
Both would be a LOT of fun to 'experience', IMO.
Old 04-20-2014, 12:11 PM
Easy Mike
Support Corvetteforum!
Easy Mike's Avatar
Received 1,469 Likes on 1,248 Posts
Cruise-In II Veteran
FWIW: Zora Duntov always felt the optional 350hp smallblock was the most reasonably priced performance option for the Corvette during the years it was available. You got a lot of bang for less than $200. He tried to save it for the 1971 model year, but the bean counters hosed it.
Old 04-20-2014, 12:21 PM
Les
Les's Avatar
I followed the LT1 closely because I bought my avatar car new and it came with the 1970 LT1 in it. As stated already, the only change for 1971 was a drop in compression from 11:1 to 9:1. The new rating method accounts for the additional power drop in 1972.
My memory tells me that they all used the same camshaft, and that is supported by the info contained in this link. LT1 internals were the same whether in a Corvette or a Camaro- http://www.nastyz28.com/camaro/z28lt1.html
The 1970 LT1 lists peak power at 6000 RPMs, the 1971 and 1972 both list a power peak at 5600 RPMs. Redlines were all 6500 RPMs except for a 1972 LT1 with air conditioning, where it was lowered to 5600 RPMs due to belt limitations. This info comes from Vette Vues Fact Book of the 1968-1972 Stingray by M.F. Dobbins. I could only speculate as to why the rated power peak differs after 1970.
Old 04-20-2014, 12:22 PM
gkull
gkull's Avatar
Received 1,329 Likes on 1,057 Posts
I just drove an all original 327/350 a few weeks ago 4 speed with gearing that had it going 65 mph@ 2800 rpm.
They run nice like an economy car. Just not a lot of get up and go, but I was never impressed with the C-5 Z06 with it's 405 HP. I always found my self driving with my foot to the floor hoping for more.
Old 04-20-2014, 12:28 PM
Mike Ward
Mike Ward's Avatar
Isn't this all rather a moot point? The chances that the engine is actually from a '72 LT! Corvette and is still in original factory configuration are pretty much zero.
Old 04-20-2014, 12:49 PM
jnb5101
jnb5101's Avatar
The Parts and Illustration Catalog shows the same part number (3972178) for the 1970-72 350 Special High Performance engine's cams(the Hp rating isn't mentioned, but there are different listings for the HP and Sp. HP engines). The 1969-70 High Performance and 1973-80 Special High Performance cams was 3896962 for the 350ci engines.
Old 06-25-2017, 08:19 PM
dustin zosky
dustin zosky's Avatar
Default HW motor
hi was reading up on camshafts to ru in the 350/350, I seen you are running a sold roller, can I ask what cam you are running and the specs please? Thanks dustinzosky@yahoo.com
Old 06-25-2017, 09:15 PM
mrvette
mrvette's Avatar
I have an LT1 induction with HEI on a 4 bolt main aluminum headed equivalent of a L98 does that count???
Old 06-25-2017, 11:16 PM
cv67
cv67's Avatar
Received 3,043 Likes on 2,602 Posts
St. Jude Donor '05
Old 06-26-2017, 12:42 AM
LT1M21Vette
LT1M21Vette's Avatar
This. You can mod the motor, and get more power easily.
To 1972 LT-1 engine question
Quick Reply: 1972 LT-1 engine question
