wiper door help please
I also read somewhere that you should hear the solenoid when you turn the key to power. Like a clicking sound. I have none of that noise that a clicking solenoid might make. just a thought/clue.
OK The black switches under steering column are pushed up and not pulled down. The vac hoses are all routed correctly. I have vacuum at the small hose on actuator relay with engine running. That is true even with the wipers off. Is it not correct to say that there should be no vacuum at this hose with wipers turned off? Isn't that what the solenoid is supposed to do? Also no change in wiper door position if I take that small hose off the actuator relay. That also does not seem correct. Shouldn't the solenoid be controlling the flow of vacuum?
Engine is running during this.
SO...if you have vacuum on the small hose going to the actuator relay...and then remove it...the wiper door ...in theory...it has to change its position.
IF you apply vacuum to the small hose going to your actuator relay (engine running) and remove it...the plunger in the relay moves and changes the routing of vacuum to the actuator pod itself...thus..closes the door.
Your headlights are the SAME way...as I wrote...so if you have vacuum going to the small hose for your headlight actuators...and remove the small hoses...the door(s) should open or vice-versa. KNOWING that the headlight actuators are the same...then if you have vacuum going to them when the engine is running to keep them shut...then the wiper door actuator relay will be the same. The small hose ( either having vacuum on it or not vacuum on it will be the SAME for both the headlights and wiper door.
IF you remove the small hose from the wiper door actuator relay and NOTHING happens...because you stopped vacuum getting to it (beacsue as you wrote..there is vacuum going to it)...then either you have a bad actuator relay...regardless if it is NEW...or your wiper door actuator is bad. You can switch the two hoses that go to your wiper actuator relay that come from the wiper actuator and if the actuator is GOOD...then the door should close.
You are trying to get the vacuum to switch (when the engine is running) on the small hose going to the actuator relays. Either by pulling down on the black override switches...or by using the wiper/headlight switch..depending on which system you are testing.
The wiper system has 2 extra parts that can effect you being able to change the vacuum operation when using the wiper switch. One is the solenoid switch below the tach...which will shut off the vacuum and allow ti to flow when the switch is turned on and off. The other part is the vacuum switch under your right wiper arm...which has to be adjusted to do its job...so removing the supply vacuum hose going to it during testing will confirm if your electric solenoid switch is working or not...and when you get that right...then adjust the vacuum switch at the right wiper arm.
DUB
I do not know how much more of this I can help you on if you are not following instructions so your feedback applies to what was asked of you to check.
I can diagnose the wiper system completely in half an hour...if not less.
DUB
wiper door fix
You are making this HARDER than needed. This system is simple to diagnose.
DUB
DUB
Ok.
I want you to try this.
The vacuum supply line that you confirmed that can switch from vacuum being on it to NO vacuum when you use the wiper switch. I want you to disconnect it from the safety vacuum switch at the right wiper arm....and run it to the actuator relay and see what happens then. What this is doing (obviously) is taking teh safety vacuum switch out of the equation.
NOW..when you test and see if the wiper door operates as designed...MAKE SURE that you have the 3 wire connector going to your wiper motor disconnected...so your wiper arms do not move. BECAUSE if you do not have the wiper arm linkage attached to the back of the wiper motor...and the arms are in the PARK position...there is no way that the safety vacuum switch will work due to a lack of tension required to make the safety switch move position.
Get back to me after you by-pass the safety switch.
IF it works...door goes up and down...with the wiper switch and also eh override switch...then your problems is either the safety vacuum switch is bad, not adjusted correctly or the hoses are not connected correctly.
DUB
DUB
wiper door
Ok.
DUB
DUB
I just by passed the safety switch by the right wiper arm as instructed with 3-prong wire connection unplugged. The wiper door goes up great and will go down with just a little nudge, ONLY by pulling down the over ride switch by steering column. Door does not move using wiper switch.
OK- just to be clear, the wiper motor is installed and linkage hooked up, so it is pushing down on switch.
Leave the safety switch out of the "loop" right now.
DO not worry about what happens to the wiper door at this time.
ENGINE RUNNING
OK...now...remove the vacuum hose that goes to the actuator relay. KNOWING that the system works with the override switch. CHECK the vacuum at the end of the hose that goes to the actuator. SO when the override switch is UP...see if it has vacuum or no vacuum...then pull the override switch down...and the condition should reverse. So if the override switch is UP and it has vacuum on it...then when you pull the switch...there should be NO vacuum.
NOTE how the vacuum switches when you move the override switch.
NOW push the override switch UP so it is OFF.
TURN OFF ENGINE and ignition
Reconnect the 3 wire connector to your wiper motor.
I do not know if you have that large electrical switch that is in between the 2 override switches under your steering column. If you do...this switch has a **** on it that is round, black and about the size of a radio ****. This switch allows you to cut off power to your wiper motor so you can stop the wipers when that are at full sweep...so you can change out the blades. IF you have this switch...when the ignition key is ON...and the engine NOT running...you can check to see if you have power going through this switch by testing it from the backside. You want to stop the power at this switch....or disconnect the small wire that you were missing on your old wiper motor...that you new one has...that attaches to that large red wire.
Get the engine running again.
NOW...with the hose still off of the actuator...turn on your wipers. Knowing that they will not move due to you stopping the power to them as needed...
Now see if the vacuum at the actuator hose is the same as when you tested the override switch. So if the wipers are off...the vacuum on the hose should be the same as that of when the override switch is off...and it should reverse as like the override switch..when you turn on the wiper switch.
If it is the same...then the wiper door should work....if not..then you more than likely have a problem in the electrical solenoid under your tachometer. Because that switch is what is changing the supply of the vacuum to the hose going to the relay.
If it works...then it is now to re-connecting the hoses to the safety vacuum switch and actuator relay and adjusting it so the vacuum will do the same when you use the override switch. The door will raise and lower as designed....then using the wiper switch should achieve the same result...as long as it worked as mentioned above.
DUB
OK...So by by-passing the safety vacuum switch...your wiper door will work as designed...but will only work with the override switch...CORRECT?
ENGINE RUNNING
DUB
ENGINE RUNNING
DUB
Completed the latest test. With override sw. up I have vac. With it pulled down- no vac. Wiper door works. With wiper sw. I have vac. with it off and no vac. with it on. So it does switch as advertised, and the same as with the override sw. So in theory, wiper door should work with both override sw. and wiper switch. It does not. Still only moves with override. Note- electric sw. in between override switches works as well. Stops arms wherever you want. So now it seems like the only thing left is to adjust the safety sw by the right arm. Correct? I have tried that but no change. Wiper door still works only with over ride sw.
Correct. Wiper door only works with override sw.
You still have the safety vacuum override switch still out and the hose connected to the actuator relay...right??? Once you get the wiper switch to work the door correctly...then install and adjust the vacuum switch
I believe your problem is in the electrical solenoid switch under your tach. Either the way the hoses connect or the solenoid itself
As you more than likely know by now:
Vacuum comes into the solenoid on the end that ONLY has ONE PORT...and the electrical connector is on that side also...then the other side of the solenoid it has two black ends on it. The hose HAS TO connect to the end that comes off 90 degrees to the side...and the end that goes straight is the vent. I have had these solenoids not work correctly in regards to the vent and threw everything off.
What does not make sense is that vacuum is flowing through the electric solenoid and goes to the override switch under the column. When either switch is pulled or turned on...it stops vacuum.
And with you testing the wiper switch when you turn the wipers on and off...and it is the same as the override switch...as it should....I am at a loss. THIS MAKES NO SENSE.
DUB
I am suspect to hose routing. I KNOW....I KNOW...you wrote that it is correct...NUT THIS DOES NOT MAKE SENSE!!!
DUB
DUB
I agree. It seems by all your tests that everything should work. I am going to change the solenoid after double, triple , quadruple checking the hoses. I want to thank you VERY MUCH for all of your hard work for me on this problem. Most people, I would imagine, wouldn't have hung in there this long and with such determination. One thing this vette (my first vette) has taught me is that it demands that determination and patience. Thanks again and I will post on this again when it is resolved.
DUB
Will do but it looks like it may be awhile. A long while. Wiper door vacuum solenoid not available for months from anywhere I have checked. I checked 4 places. Thanks again.
#33
It does NOT make sense that you have NO vacuum when the wiper switch is ON...which is telling me the solenoid is working.
This is baffling.
DUB
#34
Working on my wiper system on a 69. I believe I have two problems. One electrical , as talked about in another post, and a wiper door problem. The wiper door stays open all the time. Headlight doors work fine. I found the wiper door safety switch to be broken and have replaced it. Unfortunately, this car seems to be one PITA. Very hard to work on. It's never just one thing. Anyway, I have vacuum going into the back (firewall) side of the wiper door actuator, but none coming out the front side. Would this indicate a bad actuator?
#35
It'll be the weekend before I can get back to it. Car is in shop for carb. rebuild and a couple other small nagging things. Front end parts ordered, appointment for next wed. for front end rebuild and alignment. Then car will be up for sale.
#36
So THANK YOU to everyone for their help!!! Now on to the next Gremlin!!
#37
Glad you got it..I knew something was wrong somewhere...it did not make sense.
DUB
DUB
