1971 Dark Saddle Dye Mix formula(SEM)
I live about three hours from anyone who can custom mix the SEM vinyl dye. I recently sent some interior parts to the "jobber" and had them mix a quart, it is in the same color family but not close enough. Has anyone got a close match to 71 Dark Saddle and willing to share the SEM formula?
Thanks, Kevin
Thanks, Kevin
Thanks, Kevin
Thanks, Kevin
The original paint,(it isn't dye BTW), would have been dupont interior color. Those were dead on as it is what was used by GM. Unfortunatly those went bye-bye, unless you get lucky with an oldtime supplier who may still have some colorants left.
When you say DuPont interior color, due you mean a paint instead of a dye? I have the Dupont interior color number but no one can x reference the mix formula. I thought about ordering dye from Al Knoch but they don't seem to know much about what it is and I am somewhat familiar with the SEM product and how to use it.
Kevin
Kevin
Kevin
Kevin
SEM is the go to for it now, but they would be using different colorant then the dupont. Again these mixes are quite close, but obviously an exact match rerquires some trail and error which means time and money.Your method of sending an actual interior piece to match is the best way to get the closest possible match. Did you ask the supplier if he would be able to abjust the scanned formula to better match ? It may be more of the mixer than the mixes
I'm thinking about making the three hour drive and just keep mixing until correct. I've had to make some compromises on the project but don't wont to on this.
Thanks for the info, Kevin
