Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-17-2002, 09:08 PM   #1
SuperFast80
CF Senior Member
SuperFast80's Avatar
Default Cam specs? Crane 272...
Anybody have the specs on this?
SuperFast80 is offline   Reply With Quote
Old 07-17-2002, 09:25 PM   #2
ORVette
CF Senior Member
ORVette's Avatar
Default Re: Cam specs? Crane 272... (SuperFast80)
www.cranecams.com
Energizer272@.050 specs
I/E duration - 216
I/E lift -.454
110 lobe centers
IO-3
IC-33
EO-43
EC-(7)
Intake lobe centerline-105deg. Hope this helps.
[Modified by ORVette, 5:27 PM 7/17/2002]
ORVette is offline   Reply With Quote
Old 07-17-2002, 09:41 PM   #3
MikeC
CF Senior Member
MikeC's Avatar
Default Re: Cam specs? Crane 272... (ORVette)
Are you talking Energizer or Powermax?
What gears do you have in the car?
And lastly shouldn't you be saving for a Big Block?
MikeC is online now   Reply With Quote
Old 07-17-2002, 09:52 PM   #4
StrayDog
CF Senior Member
Support Corvetteforum!
StrayDog's Avatar
Location: Ipswich, Massachusetts , USA, Home of the Clam. Massachusetts
Crane has been advertising the 272 in various magazines stating the 272 out Preforms the Comp Cam XE 262 in tourque & HP, On a 350 chevy up to 6000 rpm.My winter project was to put the XE262 in my 427, may consider the 272 , but have a few months to do more research , looking for big mid range TOURQUE , for my street driver ,compatable with my 308 rear gears & the breathing of Endlebrock Alum heads...currently best ET with L36 CAM , 13.7 @102 mph,,,, :) :seeya :flag
[Modified by StrayDog, 8:58 PM 7/17/2002]
StrayDog is offline   Reply With Quote
Old 07-18-2002, 08:15 AM   #5
SuperFast80
CF Senior Member
Actually it is a PowerMax 272 (HMV-272-2-NC).
Old 07-18-2002, 08:42 AM   #6
vettfixr
CF Senior Member
vettfixr's Avatar
This from my website
The camshaft was replaced with a Crane HMV-272 Max Velocity dual pattern hydraulic cam. The cam has a duration of 216 degrees intake and 228 degrees exhaust @ .050 lift and has a max lift of .454 inches on the intake and .480 on the exhaust.
If I remember correctly the cam is ground on 114 degree lobe centers. I can tell you that it's a really nice cam that idles well down to about 850 rpm and wakes up nicely at around 2200. I didn't give up very much torque down low and can lug the engine around town in 4th at 1200 rpm all day.
[Modified by vettfixr, 7:43 AM 7/18/2002]
vettfixr is offline   Reply With Quote
Old 07-18-2002, 10:30 AM   #7
gkull
CF Senior Member
gkull's Avatar
I installed this cam many years ago in my 355 Vette motor after reading a Hot Rod mag. article. They were able to get a dynoed 382 hp with Sportsman II heads 9.5 c/r and 600 cfm carb. I used 1.6 CC roller tips to get more lift and my motor was more modified than the HR test motor. It was a nice cam and I was able to get 12.60's second 1/4's.
I have since installed it in a few pickup trucks because it's such an all around cam.
gkull is offline   Reply With Quote
Old 07-18-2002, 04:42 PM   #8
flynhi
CF Senior Member
I used one for years in a 355 with carb and later with TB FI. It was a great little street cam.
flynhi is offline   Reply With Quote
Old 07-18-2002, 09:29 PM   #9
StrayDog
CF Senior Member
StrayDog's Avatar
Default Re: Cam specs? Crane 272... (gkull)
WOULD the 272 be a good cam for my 427, alum Endlebrock heads & 9.5 comp ratio ? looking for fat mid range tourque, ..........The dog. :confused:
[Modified by StrayDog, 8:30 PM 7/18/2002]
Old 07-18-2002, 09:47 PM   #10
Paul 75 L82
CF Senior Member
Paul 75 L82's Avatar
Send a message via AIM to Paul 75 L82
Default Re: Cam specs? Crane 272... (StrayDog)
I'm really at a point that I don't know what to do next. 1st I installed the comp 262 roller cam in a 88 IROC with TPI and 700R4. It was great. So I installed the hydraulic 262 in my vette and it's great. Now I'm getting ready to build a 383 for my 73 Z-28 and I don't know what to do. I read that the crane powermax 272 is advertized as better than the 262 but I don't know. As so now I think I might try it out. Does it have a rougher idle? And as much torque ar the 262?
Paul 75 L82 is offline   Reply With Quote
Old 07-19-2002, 10:20 AM   #11
StrayDog
CF Senior Member
StrayDog's Avatar
Default Re: Cam specs? Crane 272... (Paul 75 L82)
I have same question as Paul, except for a big/block , anybody out there..................... :confused:
Old 07-19-2002, 05:19 PM   #12
Paul 75 L82
CF Senior Member
TTT
Reload this Page Cam specs? Crane 272...
Tags
114, 262, 272, 2722nc, 350, 6000, cam, cams, camshaft, chevy, comp, crane, hmv, max, velocity, xe
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
