What's the best product to clean vinyl?? (dash, door panels etc.)
Re: What's the best product to clean vinyl?? (Gonzo)
My girlfriend takes care of the cleaning... I don't do too much in my household myself....
:cheers:
Olivier
Dang you must be from Maimi, How do I get my wife trained like that :D :D
Gonzo
:cheers:
Olivier
Gonzo
:cheers:
Olivier
Re: What's the best product to clean vinyl?? (GrandSportC3)
I like to be different. Whatever you use to clean with is fine but for protecting the vinyl I found over the years that the best thing is SUNTAN OIL with a 30 or higher UV blocker #. Not lotion ... Oil.. It smells good and really works in sun belt areas. I Have NEVER had a car with a cracked dash. I have been using oil for about 20 years . Think about it!
Re: What's the best product to clean vinyl?? (silvervetteman)
oil for cleaning?? I wouldn't have thought about using oil - but it's great if it works!!!
:cheers:
Olivier
Re: What's the best product to clean vinyl?? (john's '81 mouse)
Agree that simple green, available in auto parts stores, K-Mart, and Walmart ect., works well to clean. (use diluted with warm water)
RE: My previous response i.e., Soft Scrub:
You already found out where to get it so, you don't need much, just a dab or two on a "wet" soft brush works fine. Small area at a time (just so it doesn't dry up on you before you wipe it off (damp Rag).
Re: What's the best product to clean vinyl?? (joe74)
Thanks for all the responses!! I will be busy trying out all the products you guys recommended!!!
:cheers:
Olivier
:cheers:
Olivier
Eddie
