MSD ignition for supercharged engines
I am using a Weiand 142 on a SBC. MSD has two controllers I am looking at, the 6BTM and the 6al-2 programmable. Also there is a black box ignition controller that looks interesting.
http://www.cbperformance.com/Product...oductCode=2013
I have looked at a few forums but wanted to see if anyone here has experience with these and what the level of satisfaction is.
Location: At my Bar drinking and wrenching in Lafayette Colorado
Received 4,925 Likes
I did a 670-horse supercharged 383, and used the MSD6 BTM with outstanding success.
This is the engine installation with the Vortech blower:
To provide boost retard, I fabricated a subassembly electrical panel with the MSD, the retard control ****, oil pressure activated fuel pump relay, and power feed for ignition and fuel system:
Installed in the engine compartment:
Running the maximum retard setting, the engine picked up 60 horsepower under boost compared to the non-retard position. The system has been operating without any issues for almost a year now.
Lars
Lars
You did and the little black box I pm'd you on is of interest too. The 6al requires a MAP sensor , BTM does not. But some of the other features of the 6al are of interest too.
Im going to call MSD and try to get more information from them before making the decision
Lars
Lars
I have one of the cheap HEI distributors with a hypertech coil. It seems to be working. I am not using vacuum advance.....yet.
So I pulled the trigger on the MSD 6530 programmable. Locked out dist by making a plate that holds all four pins in place. I had previously installed a max advance stop so that's where I locked it out at. 32 degrees max advance. The beauty of this ignition is the ability to custom tune advance via the laptop. I have the 2 bar Map sensor for boost retard signal. I can plug the laptop in and make a run and see what's going on, or at least a copilot can. As soon as the rain stops will post my opinion and experience. I know at least one member who was looking to do this with a similar engine config.
http://www.microsoft.com/en-us/downl....aspx?id=24601
The free version allows you to record 10 minutes max. Plenty for 1 run.
Also watch this video on rotor phasing. It is worth checking when using a retard timing controller. I am also using the 6530 programable with a MSD 85501 locked dist. I checked the rotor phasing of the stock rotor and surprised how far off it was. Bad part for this testing is you need to modify 1 dist cap.
I find this unit easy to use and you can quickly load saved curves. The harder part is working with the MAP sensors and knowing what to change and when. Takes a little trial and error. This sure beats replacing springs and weights in the dist. Since I dont drag race I cannot use most of the features for burnout / lauch curves etc. Anyone that likes to drag race would find this great to maximize there tune. This only falls short of a complete ECU system.
It does take a little getting use to think about how much retard vs how much advance, but once you are past that its simple to understand.
Enjoy.!
You can use the following to screen capture your laptop. Includes a screen recorder app.
Enjoy.!
MSD Tech: Rotor Phasing - YouTube
Enjoy.!
Your gonna have to let me look at the install when I get back from the slope.
