Need help with 1980 signal lights.
So I have been battling out some on going issues with the directional lights on my '80 corvette. So far I've replaced the flasher, fixed a bad ground, checked all bulbs ,and cleaned the sockets up while I was in there. But things still don't seem right. The hazards work great but when I use my left/right signal the front blinker and front corner panel indicator blink at opposite times (is this normal?) and the white front corner panel light comes on constant.. only when I signal to that side, no other time. Whether the headlights are on or off. Seems weird right? Also my right indicator light on the dash doesn't work, I replaced all the bulbs in the cluster.
Any input would be really appreciated!
first thing to check is the bulbs, make sure that you have the correct bulbs in the lights, it wouldn't be the first time I've seen dual element bulbs in single element sockets and vice/versa.
then start checking the grounds again, there are a couple on the nose that can cause issues.
the right turn indicator could be either a bad bulb socket or the film "circuit board" on the back of the gauges could be messed up, they are VERY fragile and it doesn't take much to mess them up, the are that the large connector plugs into on the back of the gauges can be a real pain too.
Received 1,470 Likes
Cruise-In II Veteran
