hood release handle '72
when i was removing the cable to remove the latch mechanism for the firewall cleanup,
the last 3/4" broke off at the bolted clamp.
is it possible to replace the 0.043" piano wire that's in the solid section of rod?
maybe drill out and braze a new piece in???
has anybody done this before?
yes, i could buy a new handle assembly, but that will take a couple of weeks to get down here...
SO it is not like ruining a part that is obsolete.
I would drill and then re-stake it somehow...instead of using heat....which can effect the integrity of the wire.
Also...when you do attempt this...take the time to attach a wire/cable for a remote release ...so just in case...you still have a way of opening the hood on the left side if your new wire/cable you install in the handle breaks.
I get spring steel wire from a spring manufacturing company down the street from my shop. I make a lot of my own springs and such when needed. I know that type of steel is what I would use due to it being able to last a long time. IF that is not available in your area...then the stranded cable for like a bicycle might also work well. If you have junk/auto salvage yards there with old American cars...the solid cables for many of the inner HVAC controls is pretty much the same and are quite strong also for what you are looking for.
DUB
just don't shut the hood completely until the new cable makes it there. or run a cable thru the hole that is used when the cable breaks.(temporary)
