Soft top date codes?
Old 01-02-2014, 02:01 PM
rponfick
rponfick's Avatar
Default Soft top date codes?
Anybody know the date code stamping info. for convertible tops? I am familiar with engine, tranny, differential, but can't seem to find how soft tops were coded. Tried searching the Forum and Corvette By the Numbers book, but haven't found any info. I might want to order a dated top, but the suppliers want vin, build date, and year. Just want to check what they may put on a dated replacement soft top.
I have a early '69, and the only code that seems to be burned into the plexiglass is what appears to be a 168 in the upper right corner of the information block on the rear window plastic. The rest of the stampings appear to be the generic information, Vinylite, A6, UCC-M-28, Do not rub dry, etc.
Thanks, Ralph
Old 01-02-2014, 02:21 PM
restoman1
restoman1's Avatar
Tops are dated month/year, so 168 would be January of 1968.
Ed
Old 01-02-2014, 02:58 PM
rponfick
rponfick's Avatar
Ed, thanks for the info. I guess tops can sit around for awhile before being used on a car. Same not true for engines, tranny, diff., etc.
My car build date of F03 (Jan 3, 1969), which would be almost a year after the top was stamped, if it was stamped in Jan., 1968.
Thanks again. Ralph
Old 01-02-2014, 03:45 PM
Alan 71
Alan 71's Avatar
Received 2,878 Likes on 2,515 Posts
Hi Ralph,
Although many parts are generally expected to have a date code within 6 months prior to the car's assembly date, convertible tops are one of the few, (windshield and door glass are others), that are accepted with a 12 month period prior to the car's assembly.
Regards,
Alan
Old 01-02-2014, 04:42 PM
rponfick
rponfick's Avatar
Thanks Alan. I alway appreciate your comments. Factual and diplomatic.
My window glass seems to be pretty spot on. Side glass is VX, which I think is Dec. 1968, and hardtop rear glass is CX, Nov. 68. Windshield has been replaced.
I guess I am a little surprised that the soft tops can sit around that long, but that was before the "just in time" inventory system.
Ralph
To Soft top date codes?
Quick Reply: Soft top date codes?
