Gutting a Catalytic Converter?
Can anyone tell me the best way to gut a catalytic converter? I was thinking of gutting the on my stock exhaust (1982 Corvette). I have the converter off the car sitting on my work bench. Nothing wrong with the converter other than it being the original one installed on the car (32 years old).
Didn’t know if this would cause any issues? Or any disadvantages? I also spoke with the local muffler shop and they said they can make me a “by-pass tube”, but with this option I will not be able to connect the air line and didn’t know if this would cause any issues.
Any help would be greatly appreciated.
A steel bar and a hammer is the usual approach, just make sure you don't damage the exterior....not the easiest job in the world, but take your time....a 3 lbs hand sledge is the best....
you need a good strong metal rod .push it into the center of cat .then take a good size hammer tap on the end and the nasty stuff should fall out .will take 5 to 10 minutes.well worth the effort.the old cats were very bad .the new ones are a lot better.
It would be a good idea to check EPA and your state EPA regulations. I cannot imagine that there is any legal reason for gutting a catalytic converter let alone advertising the fact on a public forum.
I am not trying to incite a political argument about the government. The EPA exists and the laws exist whether you like them or not. The consequences are real.
Gutting the cat is an old trick, but the cement drill is a new one on me, I like it, should make the job go a lot quicker. The goal is to reduce the guts to pieces small enough to fall out through the inlet or output, sometimes tough to do with a rod and hammer. The good part is it's cheap to do, and will still pass a visual inspection. It will change your exhaust sound, it'll be a little louder, not much though. No idea how it will effect the computer, but I would imagine it would not pose a problem, that's just a guess, though.
Scott
Scott
Technically it is illegal.
Use a long air chisel to break that stuff up to drop out the other end over a garbage can and then have a pipe slid in through it at a muffler shop (typically an independent shop that takes cash ) because it will make kind of a hollow drone - so I've heard
I have a 1999 Camaro Z28 6-speed with only 29,614 miles on it. I took off cats and all the emissions equipment, installed long tube headders and an off road racing SLP exahust system. I sent the PCM to Texas Speed Shop and they removed all the emission signals. I do not live in an area where they test for emission, but for the fun of it I drove to one and guess what? It PASSED! The idiots that work there didn't even look for the stuff that was missing, but they did commented that the car was loud....LOL
Anyways the Cat for my 82 Corvette is done and it took about 10min. After I beed blast it and paint it with a High Temp Cast Iron Gray Paint I will post a few pics if anyone is curious. I did find out that the O2 sensor will be just fine and the noise should not be too bad, if it is I will just order a high fow converter in the spring.
Thanks for you help and comments
Nam Labrat
Received 4,153 Likes
Just theoretical, of course/Check your EPA Rules:
Some gutted cats produce a rumbling sound within the cat which can be annoying/some don't.........a section of exhaust pipe pushed inside the gutted cat and welded on both ends to prevent rattling cures the rumbling problem.
For entertainment purposes only....LOL
