Should I get a Spreader bar?
Need some advice...I have an 81 I am about to change out all of the worn out rubber bushing to poly's. I have seen several images of guys who also run with spreader bars (like this one at ecklers:http://www.ecklerscorvette.com/corve...Product_Viewed
Since I'm new to C3's and GM's overall...is there a benefit? to me 100 bucks ins't bad to add to the strength and drivability, again if that’s what it will do
Do a search of the C3 Tech forum. There have been numerous threads about spreader bars. The posts range from 'CAN'T HURT' to 'GREAT IMPROVEMENT', with most responders saying that it helped their handling and stability. I have a spreader bar similar to the one from Eckler's on my 77.
"While you are at it" (famous C3 phrase!!) you may wish to consider changing to tubular upper A-arms that allow for an increase in caster. Most C3's lose this adjustment as frames sag over the years, the steering lightens up excessively and the car becomes twitchy and darty on the highway. These A-arms restore the caster adjustment and will allow 4 to 5 degrees caster. This was the single best improvement that I made to my suspension (apart from 17 inch wheels and modern tires).
The frame flexes a lot more than you think. If you will be doing any spirited driving and not just parades and static car shows, you will feel a difference. I had one, and made a bunch of changes to the car where I had to remove it. I will be making a new one to fit. Your alignment guy will hate it.
Nam Labrat
Received 4,156 Likes
Being a rookie, the other reason that I found in the forum would be to "widen a collapsing frame" (the engine crossmember has "bowed" and the frame rails are closer together than they were from the factory) back to the original dimensions.
The ORIGINAL and bestest
Toronto Events Coordinator
The effects of adding a spreader bar are immediately noticeable, whether driving in a straight line or around corners. It tightens up the front end tremendously. It is the best bang-for-the-buck suspension mod....nothing else will make such a difference for so little money.
Perfect, this is the exact advise I was looking for, thanks a lot guys !!
Happy New Year - may we all win the lottery so we can really do what we want to our vette’s :P
It's made by SpeedDirect, a Forum Sponsor. You can see it on their site. It did make a "mild" difference but that really depends on the condition of your frame and the type of driving. With my 1974 the car came from a dry (non-coastal) area of California so the frame is very solid and my driving is ... pretty mild as well. It is certainly a worthy addition at the price.
its made by speed direct, it clears the fan just fine, i slid the bracket toward the engine as much as i could and had no issue.
The best bang for the buck by far for steering and handling! As 7t9l82 stated as well the effect of a spreader bar is immediate. I have had mine for several years now and the effect on ride, steering, tightness of the front end is dramatic.
Really quite perplexed by comments that the spreader bar effect was minimal or small on their C3's. If C3's with a spreader bar installed don't notice a dramatic effect on the chassis, something is wrong. Either the bar is incorrectly installed or not properly tensioned.
110%
110%
I have the higher mount VB&P spreader bar made for no mechanical fan.
with the frame being thinner in the 1980-82 vette it should help alot .in another thread on here ,a member posted pics of his ripped front cross member .I too am considering a spreader bar .
Have to look at the whole pix here guys, if your car is a stock machine, adding just one thing will do little, but if you add it after a comprehensive package, which means from tires/wheels/springs/shocks, all upgraded to say C4 specs you get FAR better handling, then upon adding the bar you really notice it a LOT....
I bought my '72 vert in '95 put on '92 wheels/tires, HUGE improvement, went VBP 460 front/360 rear springs, obvious all moving parts replaced also....some years later went for rack steering (another topic entirely) and so then the front cross support....which made a HUGE VERY BIG improvement, the A-B was proven for me by just dropping one end and driving around the block, then putting it back and driving it again....CASE CLOSED!!!!!!
the beast handles great....HUGE improvement with that cross support, ...
