Auto meter speeds & tach install
Not the best pic but that all I have now.
Autometer SportComp
George
Autometer SportComp
George
I tore everything off housing and tapped into stock wiring harness for blinkers/brights/tach and for power to the gauges. The little 194 lights fit in the factory housing just like a replacement light would but the lights have pigtails on them. I used LEDS in place. Nothing from the gauges to the wiring harness is hardwired. I used male/female connectors for simple plug and play. Easy to remove if I need to in future too. Same goes for my center gauge cluster. I left factory connectors for me to convert back easily if I wanted, I doubt I ever will though.
Yes I sanded the top down and painted with light coats out of a rattle can. (satin black I believe)
I am saving this picture for the future.
thanks for the post
Here is a picture of the back side. You carefully gut the plastic housing until you have enough room. Aluminum plates were made to hold the gauges in the correct position. The center mounted lights can be retained by filing the openings so that plastic bulb holders can be installed.
The eleven wires will be spliced/crimped in a single 12 pin male/female molex type of connector.
I used a die grinder with sanding drums to slowly open up the housing to suit my needs.
New thin aluminum face plates were fabricated and then painted satin black. They were then glued over the original face plate.
PIN ASSIGNMENT
1-Right turn sig
2-Left turn signal
3-Hi Beam
4-Brake light
5-Speedo signal
6-Tach signal
7-Ignition voltage
8-Ground #1 (for center mounted lights)
9-Ground #2 (for speedo and tach)
10- Trip Reset button
11-Gauge lights
12-empty
PIN ASSIGNMENT
1-Right turn sig
2-Left turn signal
3-Hi Beam
4-Brake light
5-Speedo signal
6-Tach signal
7-Ignition voltage
11-Gauge lights
12-empty
2020 Corvette of the Year Finalist (track prepared)
C3 of Year Winner (track prepared) 2019
Haven't reached the point of driving yet. I'll try to get some install photos but I think the angled gauges will make visibility just that much easier from the driver seat.
wondering how they drive the speedometer, my trans has a cable, is there a gps or something to run an electric speedo.
I put the 5" monster speedo and tach along with a set of 2 5\8 gauges in the center. Made some plates that went where the stock ones hooked to the dash pad and did the same for the others in the center.
