Carb on the way back!!!!
Old 12-10-2013, 02:37 PM
mk's78
mk's78's Avatar
Default Carb on the way back!!!!
Hello fellow C3's,
My Qjet is on it's way back from the rebuilders and I have two questions for the Forum panel of experts...
1....Is there anything needed for the threaded portion of the fuel line nut to the carb such as Teflon tape or thread seal etc????
2....Same question for the carb to intake manifold gasket?????
As always...thanks in advance for your timely and professional support..
mk's78 Mike
Old 12-10-2013, 03:12 PM
MelWff
MelWff's Avatar
Received 1,817 Likes on 1,606 Posts
1. Normally no.
2. The gasket is used dry.
Old 12-10-2013, 04:34 PM
scottyp99
scottyp99's Avatar
A lot of people say to run carb-to-intake gaskets dry, but I have this thing about putting stuff on gaskets. Lately, I have been having great luck with Permatex Copper Spray-a-Gasket. It seals well, and when it's time to remove the gasket, it stays stuck to the gasket, not the intake. I used High-Tack for years, if you use Felpro Karropak gasket material, it stays stuck to the gasket when you remove it, but it's kind of messy to work with when you're installing. I know, some folks will call me Bubba for doing it, but hey, I hate leaks!
Scott
Old 12-10-2013, 04:58 PM
mds3013
mds3013's Avatar
I use anti seize on line threads, a little on male and female. The threads do not do the sealing, the flare does. The anti seize lubes the threads which allows them to tighten evenly and will allow you to remove them easily in the future. Put some on the tubing where the nut fits also. mike...
Old 12-10-2013, 06:52 PM
Jeff_Keryk
Jeff_Keryk's Avatar
The fuel inlet seals via the flare, not the threads. No Teflon tape! Use a little white grease as a lubricant. And hold the 1" fitting while tightening the inlet with your flare wrench.
Old 12-11-2013, 09:55 AM
lars
Support Corvetteforum!
lars's Avatar
Location: At my Bar drinking and wrenching in Lafayette Colorado
Received 4,926 Likes on 1,931 Posts
That's correct. Do not use Teflon tape - that's for pipe threads. Put a little assembly lube on the back side of the tube flare and on the threads to prevent galling and to allow proper torque of the inverted flare nut. The carb gaskets are installed dry. Don't over-tighten the carb hold-down hardware.
Lars
Old 12-11-2013, 01:51 PM
LeMans Pete
LeMans Pete's Avatar
St. Jude Donor '13-'14
Old 12-21-2013, 10:28 AM
vettefred
vettefred's Avatar
Good tip....another I use is to glue the intake gaskets to the head with yellow 3M adhesive and then paint the intake side of the gasket with anti-seize. This way you can remove the intake without tearing the gasket. It seals well and can R&R'd many times without replacing. Old school drag racing trick I used in the seventies.
Fred
Old 12-21-2013, 11:13 AM
gcusmano74
gcusmano74's Avatar
To Carb on the way back!!!!
Quick Reply: Carb on the way back!!!!
