need some leaf spring help
Old 12-09-2013, 11:41 PM
Jazper24
1st Gear
Jazper24's Avatar
Default need some leaf spring help
I have replaced the old leaf springs with new yet the holes are not lining up with the trailing arm. The holes are about two inches behind the trailing arm causing the spring bolts to be diagonal. What could cause this problem?
Old 12-10-2013, 07:27 AM
Mooser
Mooser's Avatar
Received 3,135 Likes on 2,069 Posts
If the spring is in the right place on the rear diff (ie sitting flat and not caught on the lip holding it on an angle) then everything is OK
With the spring arched down and the arms in whatever position they might be things look out of whack.
Only when it's together and sitting that matters
M
Old 12-11-2013, 06:50 PM
DUB
DUB's Avatar
Received 2,713 Likes on 2,321 Posts
What year???
Did you replace with a steel or fiberglass spring????
IMPORTANT///please respond.
DUB
To need some leaf spring help
Quick Reply: need some leaf spring help
