AmericanRacingHeaders adds an "LS SWAP" header for the C3 owners................PICS
#41
NICE! I think AR does some of the best header building in the industry. Only one thing on my list to Santa this year. So now it looks like your 71 will be hitting the road in 2014 hopefully same for my 72 LT-1 Good luck with your build Gordonm
#43
That is what hydraulic throwout bearings are mdae for, I'm not a big fan of them but, they have worked trouble free for many thousands of miles in my C5/C6 Z06 Vettes. I think I'm going to make an external "pull" type slave cylinder that will fasten to my Quick Time bellhousing (steel) I'm sure Dave Herlinger could do the same for you, I will bring my by Daves shop when I get it done, far easier/quicker to build hydraulic clutch system than to build a nice set of stainless headers! My LS3 isn't a "crate motor" it has better connecting rods, Mahle pistons, bigger cam, I need headers for proper performance, I'm shooting for 480RWHP or over 500HP at the crank even the LS7 manifolds probably wont do the job for me.
#44
Received 1,139 Likes
That said, let me know when you are going to be by Dave's, I will PM you my contact info.
#45
Steve only concern I will have is clearance to Borgeson type aftermarket steering box. The Borgeson conversion is far more popular than rack&pinion conversion. This Delphi 600 series steering box which is about 1/2" further towards the motor than OEM gearbox. Other wish would be to clear Z06/ZR1 style water to oil cooler which side mounts by oil filter. I am also looking at your GEN1 headers for the Vette and they seem to have a more pronounced merge collector on them is it an optical illusion. I'm sure the feedback from the C5/6 community has given you guys the best route to take in collector design so I trust you guys on your design here. Looks like your will have a great product line for the C2/3 generation of Vettes! Thanks for your efforts, I intend to place my order soon
#46
SolidLT1 I don't think the Borgeson will be a problem. There is ample clearance on the drivers side tube around the shaft that goes down the the rack on mine. This was a no go at all with the Melrose headers. I had to weld in a big bend but on the AR headers it is already there.
#47
2020 Corvette of the Year Finalist (track prepared)
C3 of Year Winner (track prepared) 2019
In 2-3 months (or hopefully less time) I'll order a set to confirm the Borgeson if all still seems to be going well and Gordon is happy with ground clearances.
#50
Ok, been following swaps for a while and just started mine.Have a78 and have a 05 gto motor w/6speed w/hydrualic throughout. Im going with a rack. Made my own motor mount plates and in the process of setting up the tranny cross member. Its a frame off project and have the front and rear suspension off. Im in massapequa and if you need pics and a ginny pig , Id be happy to help everyone out. Id have to see if I could borrow a friends trailer though.
#52
I could not get in touch with my friend that has a trailer. I will try again on thurs. He is away with the holidays here. I will give you a call on thurs in the AM and tell you what I got and hopefully we can proceed, possibly as soon as thurs . Like most people doing this swap, its been a gamble with what other people have experienced and can get very costly very fast . Hopefully, we can solve this problem and have performance at any LS size to boot. Happy Holidays
#53
Premium Supporting Vendor
Gordon will be here again next week.
We will be going off the DirtyDingo "slider" C3 LS swap mounts
#56
#57
Thanks for the tour Steve. My son and friend have been talking about how much goes into making headers.It was a learning experience for them. Phil is on his game and willing to proceed in any direction to make things correct which we all can appreciate. You have a great shop. I talked briefly with Gordon and we seem to have parallel builds though he is much further along with his.Nice guy . Monday we are going to try to finish our convo and have to see if the headers will fit using my mounts as well with factory ac box and etc. I believe his motor is mounted in the same position. Thanks for your time as well. I am going to try to put some time into making the tranny cross member so I can b ready for when you make a second set. Let me know. Thanks again. Pat
#59
Eagle, give us a call.
Gordon stopped by today to go over the mods needed, very small tweak on one of the primaries.
The BIG factors:
1. Motor mounts
2. Steering Rack used
3. Z bar or hyd. clutch???
The BIG factors:
1. Motor mounts
#60
I'm in once I get the thumbs up from Gordon.
Mine is an LS3 480 hp hot cam'd crate motor, stock position motor mounts, hydraulic clutch, and Flaming River rack.
