heads for goodwrench 350
I have the 260hp Goodwrench 350 engine. I want to do something like they did with the Goodwrench quest 350.
I will be using a qjet and performer intake.
Goodwrench quest used trickflow 195 which gave the engine a little over 9:1 static comp.w/ 64cc chamber
I am thinking about the trick flow 175 w/ 56cc chamber to raise the static comp to 9.5-9.8 using a cam similar to the comp ex268, lunati voodoo268. Or a equivalent hyd. Roller. Another head I am considering is the EQ180 with 50cc chamber with will raise the static comp. To over 10:1. But with the eq being a iron head I would have to consider detionation an d need a larger cam to bleed off cyl pressure.
Car is 1980 4sp with 3.73 gears. Spirited street driver, stop light to stop light runs..occasional 1/4 for fun.
Would these small cc heads be a better choice vs the 64cc heads that also have larger runners as well? Dart shp180 brodix ik180 profiler 180 ect. Which one?
