Has anyone ever seen a Rochester 7040212 Carb?
Corvette Black Book shows this carb as the 2nd design for a 1970 350/300 car.
My car has a birthdate of 6/24/70 and I have been told by NCRS people that this is the correct number for my car.
I have also been told (by a person that says he has the books) that GM engineering books doesn't list this number and it wasn't produced.
I am a novice when it comes to C3's and just want to get to the bottom of this.
Does anyone have one or has anyone ever layed their eyes on the numbers on the carb itself?
NCRS Members, please feel free to chime in here. I need to know.
You can email Lars for a more up to date document but on this version he does not list that carburetor number.
http://www.corvettefaq.com/c3/QJetTuningPaper.doc
Location: At my Bar drinking and wrenching in Lafayette Colorado
Received 4,926 Likes
The Delco/Rochester Parts "C" Bulletin published November 1980 (which is the master carb listing and spec/parts list for all Rochester carbs), does not list the 7040212 carb number, neither as a production carb or as a crossover to any other number as a booking number.
If anyone has a copy of the actual Bulletin 9C spec sheet for the 7040212, I would really like to have a copy of it so I can document the actual configuration and application of this carb number.
Lars
V8FastCars@msn.com
Lars
V8FastCars@msn.com
Received 1,469 Likes
Cruise-In II Veteran
Do you have the 1970-72 NCRS Judging Guide? It may address the 212. I have a copy but will not be able to take a look until this evening.
Are you intending to have your car judged? Which carburetor is on the car now?
The NCRS Judging guide show the 7040212. It's for a 1970 300 base Automatic. It says that it's a 2nd Design, ECS indicates Corvettes equipped with Evaporative Emissions Control Systems..
according to this 7040202 is for Chevelles and Camaros
http://www.lbfun.com/warehouse/tech_...ng%20Paper.pdf
http://corvettec3.ca/carb.htm
If anyone has "real" documentation on this carb number, I'd really like to see it (the NCRS is not the original source, and the fact that it's in their "book" does not mean anything without factual original source backup).
Lars
Received 1,246 Likes
Does this mean anything?
That carb number is on page 4 of the 1970 Corvette listings.
http://www.gmheritagecenter.com/gm-h...tion-kits.html
That's my point: The carb number just keeps showing up on random secondary "lists" as being an OK number for a Vette. I have no doubt that the number exists (I've seen them and worked on them), and I really don't doubt that they were used on Vettes. But where is the primary documentation from Rochester/Delco with the 9C Bulletin to show the 64 part numbers in the carb, the actual application, and all the specs? Where is the primary documentation for this carb? If anybody has it, please send me a copy..!
Lars
Lars
