Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 10-12-2013, 11:50 AM   #1
Capkunu
CF Senior Member
Capkunu's Avatar
Default Shift lever ignition engage
Trying to sort out a small (hopefully) issue with the 350 auto Parking/Ignition engage switch.
I have to push the shift lever lightly upwards to engage the starter circuit. When I put the lever into neutral and re-engage Park, I hear a linkage (solenoid?) clicking in the steering column - which I assume - is the steering lock mechanism. Could there be a connection? Is there an adjustment and/or lube-point to address? Or is it likely the ignition lock out switch - which is located - where? (Waiting for my shop manual to arrive).
The car sat for awhile and I've been freeing up several stuck and/or squeeky moving parts.
Thanks.
Dan G>
Capkunu is offline   Reply With Quote
Old 10-12-2013, 12:38 PM   #2
TimAT
CF Senior Member
TimAT's Avatar
The neutral safety switch is mounted on the shift lever under the top of the console. From your description, my take is you are pushing the lever more towards park to get the starter to engage. If that's the case, most likely that switch needs to be adjusted. Not a big deal to adjust, remove the screws that hold the trim plate on the console and you can see the switch. Loosen the 2 screws that mount it and move it a little and try it again. May take a few tries to hit the sweet spot.
THe noise you're hearing from the steering column is the anti-theft feature. There's a cable from the trans to the steering column that also locks the trans in park when the key is in the lock position.
TimAT is offline   Reply With Quote
Old 10-12-2013, 05:01 PM   #3
DUB
CF Senior Member
Actually ...the cable that runs from the transmission shifter linkage point to the steering column is for making sure you have the car in PARK. Because you can not remove the key unless the car is in Park with this cable working as designed. So it is a safety feature...not anti-theft.
Often times...if you remove the cotter pin that holds this cable end on the steering column tab (on the engine side...basically against the firewall)...and by turning your ignition key...take that tab and go down with it and feel for binding. if this tab will go up and down easily...that is a good thing. Because often times I have encountered the grease that GM used to lubricate this rotating assembly in the steering column has gone bad and the grease has actually hardened and got crusty. IF this is your scenario...the column has to be broken down to get to the specific point to get the tab to rotate very freely.
If you are hearing a scrubbing action. the chances are the bearings in the column are worn out...thus allowing the column shaft to have play in it and it then begins to scrub....OR ...the plastic housing at the base of your column ...just before your speedo/tach panel, is broken and the aluminum housing that rotates in it is rubbing against the plastic cover that sis cracked or broken and not straight.
DUB
DUB is offline   Reply With Quote
Old 10-12-2013, 08:24 PM   #4
Capkunu
CF Senior Member
Capkunu's Avatar
Thanks Tim. I tried that and, for the life of me, I couldn't get a grip on those hex screws. The bottom one is especially difficult; it's located in a small well which makes tool work a huge challenge. I tried every wrench in my inventory with no joy.
After I gave up trying, I checked the shift plate bolts (much easier to access). The lower right bolt was loose, so I tightened it and lubed the shifter spring. Now, it doesn't take two hands (one to turn the key, the other to hold the shifter towards park) to start the car. Most always it starts normally - or - it takes a small upward nudge of the shifter to get 'er going.
I can see how that switch works, but I need some tool advice how to loosen those hex screws.
PS: I may've forgot to mention it's a '76 'Vette.
Thanks for you help.
Dan G>
Old 10-13-2013, 04:57 PM   #5
DUB
CF Senior Member
Sometimes you have to remove the bolts that hold the shifter to the floor so you can raise it to gain access to the screw you are having trouble with currently.
DUB
Old 10-13-2013, 06:07 PM   #6
Capkunu
CF Senior Member
Capkunu's Avatar
Quote:
DUB
Duh!! Sometimes the obvious is so obscure.
Appreciate the tip; will try that next.
Dan G>
Reload this Page Shift lever ignition engage
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
