Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 10-12-2013, 10:53 AM   #1
Nomad09
Junior Member
mrtarr77@gmail.com
Default Battery drain in 77
Wondering if anyone out there has done any work on the fuse block. My windows stopped working and found a connector had come apart. I put he pink wire back together and ever since my battery drains overnight. It seems like a strange setup as it looks kind of like a jumper, trying to look for a wiring diagram, but so far nothing helpful. Any ideas?
Nomad09 is offline   Reply With Quote
Old 10-13-2013, 05:47 PM   #2
DUB
CF Senior Member
Your power windows ( if connected correctly) should not drain your battery. The reason being is that circuit is DEAD when the key is out of the ignition.
The only way your battery gets a drain is by a component that is still drawing current when the key is off....which means that usually the circuits causing this are those circuits that stay POWERED UP ...even with the key out of the ignition. SO, interior lights and timer controller, alarm system components, I have encountered a bad alternator once...but this is rare, rear compartment light is still on...due to being a part of the interior light circuit.
They sell a tool that you can connect to your negative battery cable and read the amount of drain in amps. You wan to shoot for no more than 200 milliamps...if possible.
DUB
DUB is offline   Reply With Quote
Old 10-13-2013, 09:58 PM   #3
gjohnson
CF Senior Member
gjohnson's Avatar
Until you get it figured out install a battery disconnect at the battery.Mine had a drain and I finally traced it to the factory alarm.Got rid of that POS!
gjohnson is offline   Reply With Quote
Reload this Page Battery drain in 77
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Turn signal and tachometer issue jtran20 C3 General 1 01-05-2014 05:55 PM
rear view mirror power playsdixie C4 Tech/Performance 0 08-06-2013 01:54 PM
Draining the Battery Yellow C-6 C6 Tech/Performance 2 06-14-2013 04:39 PM
1969 vette battery being drained Jwalker63131 C3 Tech/Performance 7 04-22-2013 09:19 PM
The dreaded battery drain cmefly C1 & C2 Corvettes 9 11-04-2012 09:22 AM
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
